Yep it's been removed. This means to me that the information was accurate.
By the way, on the model three owners club forum they are now joking that you work for Tesla, because right after you asked for the URL it was taken down by Tesla
As someone else mentioned a while ago, we cannot have Model 3 holding up the line when a Model S is waiting.However, the same improvement in a small-pack, efficient EV would actually significantly improve charge times. For a 50kWh pack it'd mean 80% in 20 minutes, not 30, on a V2 supercharger.
Elon has been cryptically mentioning keeping some model three powder dry. I wonder if it has to do with supercharger V3?By the way, here's one more thing that occurred to me. A battery chemistry or cooling improvement to improve maximum charge rates wouldn't have all that meaningful of an impact on Model S and X charge times. It might bring the charge from "80% in 30 minutes" to "90% in 35" minutes, or something similar, but ultimately they're going to be limited by the current that the superchargers can deliver (until Musk starts building out the V3 network); the 0-80% time would not significantly decrease, only the charge percent at which the charger has to start throttling back..
I wonder if Tesla has such a chemistry / cooling improvement up their sleeve - whether at launch, or at some point in the next few years?
Where do you think the car measures the power it consumes?
Speaking of losses, I'm losing my mind waiting for tomorrow. I don't know if I'll be able to sleep tonight.Doesn't matter. You put some amount of energy into the car from the wall. Then some amount leaves to propel the car. There are losses everywhere.
I don't think so. Charging is already pretty darned efficient. Using what we currently know, the Model 3 should weigh something like ~15% less than the Model S, and have ~16% better aero.Is there any chance the .237 could be from the wall? Could they have made a dramatic improvement in charging efficiency?
Are you including any differences in frontal area ?I don't think so. Charging is already pretty darned efficient. Using what we currently know, the Model 3 should weigh something like ~15% less than the Model S, and have ~16% better aero.
Yes. 2.24 m^2 for Model 3 vs 2.34 m^2 for Model S.Are you including any differences in frontal area ?
The EPA testing isn't done at (only) 65 mph. The testing is done at a wide range of speeds, temperatures, etc.I used 2.22 m*m and 1800 Kg for the Model 3 and and 2.34 m*m for the Tesla and came up with ~ 40 Wh/mile difference in combined road and aero drags between the cars at 65 mph (105 kph.)
Yggdrasill, do you have a prediction for the 75kWh EPA rating, based on your assumptions and calculations?The EPA testing isn't done at (only) 65 mph. The testing is done at a wide range of speeds, temperatures, etc.
With no ancillary losses, identical tires and a perfect battery and drive line, a car with 10% lower weight and 10% better aero will be rated at exactly 90% of the consumption of the reference car.
(2.24 x 0.21) / (2.34 x 0.24) = 0.837I know. It just seems like 65 mph works out in many cases.
In this case the Model 3 Aero is 0.9*21/24 = 78% while the weight is 85%, both compared to the Model S.
The Aero will have a greater weighted effect
My most recent estimate was here (I think my estimate a few months ago was 295 miles):Yggdrasill, do you have a prediction for the 75kWh EPA rating, based on your assumptions and calculations?
I redid my calculations, and there wasn't much difference. I used 2.24 m^2 for Model 3, and 2.34 m^2 for Model S. (I've always used the Model S as the benchmark, so with the Model S having a lower front area than I thought, the difference was actually smaller with the new figures.)
I arrived at 298 EPA miles for 75 kWh pack (77 kWh gross, 74.6 kWh net) and 236 EPA miles for 55 kWh pack (57.8 kWh gross, 55.4 kWh net).
Say, your real name doesn't happen to be Reince Priebus, does it?Hahaha oh geez... I hope I don't end up accidentally becoming the center of a new storm of corporate intrigue, I had enough of that during Aptera's collapse
(Long story short: when Aptera's board hired Paul Wilbur, who then proceeded to run the company into the ground, I started publishing leaks from the company, which apparently set him off on an angry hunt for the leaker. The truth of the matter was, there was no "leaker", singular - almost all of the people who were in any position of significance in the company, apart from Paul and his friends, were leaking to me Why to me, I'll never know...) Moral of the story, corporate morale matters, and if your staff thinks you're ruining the company....)
