In Europe Tesla has complied with the EU standard for EV charging. And when it's more settled, they will here as well.
Just to add a few data points to the discussion here...
I do not know
(almost) anything about the plugs and connectors in NA, but here in Europa things are a bit different as
@sandpiper says. At the time they designed the Model S there was
(as far as I know) any accepted standards for charging, so they just had to make their own solution. But when the time had come to modify it for the European marked, Meneske Type2 was the accepted standard for AC charging
(see picture in @MorrisonHiker post above), so they designed Model S for Europa with a Type2 connector instead of the "
Tesla plug" you have. But the CCS was not yet decided on, so for Supercharging they went with an alternative runner-up called DC-Mid and modified it a bit. This uses the same Type2 plug as AC charging, without the bottom pins of the CCS/Frankenplug.
So
here I think it should be possible to design a charging port on the Model 3
(and later for S+X+Y and all others) that is capable to use both Type2 AC, Tesla EU-SuperCharger and CCS.
This also shows that Tesla does design for the accepted standards when there is any, so I do think
@sandpiper is correct in that Tesla now will design their cars from now on with the "
FrankenPlug" in mind. The question is if they will - for the NA marked - put in two charging ports on the car, or do the change on the superchargers and give existing owners an adapter.
