How have people found speed assist to work? My understanding is that it is supposed to fall back to GPS data if it can't read the signs, but it also seems that it overrides GPS data if it thinks that it has successfully read the sign, even if the two values are quite inconsistent. For example, I've seen it misread an 80 as 30, and set the current speed limit as 30 despite that being an invalid speed limit (as far as I know) and extremely unlikely on a highway. It would presumably also be a large variation from what's listed in GPS databases. It also seems to have a lot of trouble reading the illuminated variable speed signs on freeways, almost always reading 80 as 60 or 'unknown' for example. In this case of course there may be no GPS values to fall back on, since the limit isn't fixed.
I spoke to the autopilot guy at TMC last week about these things. For the LED signs he suspects they flash at a different rate to what Germany uses (which speed assist sees). The 80/30 problem is known and I have noticed in the last couple of weeks it's gone away and replaced with a problem where it seldom sees 80 at all. He said they would look at it.
Interesting info, thanks Ray. Did he mention anything about how or when it chooses to override the GPS info?
Until recently I had the opposite problem where GPS data would override the camera, leading to the situation in a construction zone (that has been under construction for a couple of years) where the car would successfully read an 80 sign, then ~20 seconds later revert to 100km/h based on GPS data; then repeat the same cycle at the next 80 km/h sign with 2.4.238 this was improved, and with 2.4.249 seems to be fixed Yes I've seen it do that consistently, and is one of the reasons I'm glad the cruise control doesn't automatically adjust to the new speed. Also, the default speed limit for built-up areas in WA is 50km/h, but my car thinks the suburban streets near my house are all 60km/h - except for the school zones which it thinks are always 40 km/h
He didn't mention that. I'm sure mine doesn't use GPS data. If it hasn't read a sign, the speed limit is displayed as '--'.
It also has intermittent success reading speed signs on overhead gantries. Is speed assist supposed to do anything other than indicate the speed?
If (while you're on cruise control) you hold the cruise-control stalk towards you for one second it will adjust to the new speed plus or minus any offset you have configured in the settings.
At the moment, it just sets the cars current idea of what the speed limit is, which can enable alerts for if you exceed it. You can also set TACC to cruise at that speed (+/- whatever increment you have set in controls) by pulling the cruise lever towards you for a few seconds.
I hope they keep it that way when autopilot steering rolls out, so that we have to action any speed change. Every LED 80 sign along the NSW M5 reads as 30...
This thread has gotten me curious. Is there really any GPS input into speed assist? I've never noticed it. It only seems to respond to speed signs. I have had the same issues with lighted variable speed signs and overhead speed signs. It just doesn't see them. This makes it pretty much useless on the Monash Freeway. It also tends to pick up the speed limits on off-ramps when I'm on the freeway dropping the observed limit to 60 from 80 or 100. I never had an issue with the 80/30 problem that others have reported. Although the other day it suddenly switched to 5 while I was in a 70 zone! I've got no idea what it saw to do that. They really have a lot of work to do before this is genuinely useful in Australia.
Yes I can 100% say my car has a GPS database of speed limits. There are no speed signs here in built-up areas yet my car usually shows a speed limit (wrong in my suburb, correct elsewhere) plus as I mentioned earlier it kept overriding the camera in construction zones.
An interesting discussion broke out when I was giving 2 friends a joy ride last weekend. They're both RACV driver instructors and they picked up the fact that Speed control and sign tracking responses were POST a sign position. I had never cared up until they pointed out if you are approaching a 60 km sign and your in an 80km zone at ,say, 79km/hr Model S kicks in speed adjust/regen AFTER you pass the sign which according to them will get you booked. The speech was along the lines that a driver is expected to BE at OR BELOW the designated speed( Sign) by the time you PASS that sign.. After they upset me with that speech I demonstrated the accel rate and scared the crap outta them :scared:.
May be right in Victoria but in Queensland you have 300 metres to change speed EXCEPT for school zones.
Or 40km/hr every time you pass a bus (buses in NSW have a 40 sign that applies when lights either side of the sign flash-not sure if this occurs in other states)
In Queensland, we don't have the 40 on the busses but do have the 40 (with time conditions) outside all schools. That also confuses it.
We have the same thing here in Tasmania, being that any bus with said flashing lights is a 40km/h zone, which is a bit frustrating when you're surrounded by 80km/h zones...
