If the argument held, we'd have such minimum speed limits posted on our freeways (and be enforced) but we do not.I made an open-ended statement without recommendations. You can measure the gap going downwards with the fastest car as the baseline (as in the above example) or you can measure it going upwards using the slowest car as the baseline (e.g. - speed limits). It should be noted that some expressways already have minimum speed postings. Anyway, I leave the making of recommendations to those so inclined.
Walk with me a bit...
Suppose we had the 80EV/70/60Truck limits (i.e. adding the 80EV). Now picture the hypermilers tooling along at 30mph to improve range.
Now imagine you're a politician and you want to address the 50mph spread of speeds. What do you do? Well, you might do exactly what I hinted at (and that would suck, IMO). Or you could look to find a way to motivate (incentivize is better than punish) car manufacturers to remove the reasons why people have to hypermile in the first place -- namely reduce high-speed efficiency penalties (aerodynamics) and increase vehicle range (larger batteries).
