Speedometer Sensor
Does anybody have an idea where the speedometer sensor is installed? Is it on the front or rear wheels? I’m asking because I plan to get different size tires for a staggered setup but I don’t want to change the speedometer readout by a significant amount.
I’ll be getting the correct size tires for the wheels where the speedometer sensor is installed and changing the size of the other set of tires.
Reactions: WarpedOne
Bro, did you find an answer to this?
I have a 19" wheel with 255/40 tire that I wanted to test on a Model Y (stock 255/45R19).
I wonder if the speedometer on a Model Y or Model 3 is based on wheel/tire rotation or GPS.
All four wheels have wheel speed sensors. You can't trick them, and installing the wrong sized tire will result in ABS/TC/SC/etc faults. Just get the right sized tires...
Wheel speed sensors?
On an ev with a fixed ratio gearbox and no clutch?
With and absolute motor position sensor?
Muhahahahaha ...:):):):):):):)
So, which is it?
Not being petulant, just wanting to see if I can repurpose tires.
I'm just full of it ... yes, each wheel has a speed sensor - it's part of ABS system.
But that does not mean you can / can't mount different tyres... it depends how big the difference really is.
Tyre Size Calculator shows 255/40R19 and 255/45R19 have 3,6% difference in diameter/circumference which is a a bit high, tolerances are about 3%.
Using these smaller wheels will give you 3% more torque and better acceleration though...
Got it. Good to know, thanks.
