Vendor SPL Racing Suspension for Tesla Model Y - Now Available!
tom @ eas
Global Vendor
Oct 11, 2021
1,239
827
Anaheim, CA
Listings
About SPL​
From full racing to high performance street applications, SPL suspension products provide adjustability and increased performance for custom alignment needs. The highest quality construction and innovative features are the reasons why our products are not only chosen by the top race teams, but also by consumers demanding the best alignment products for their high performance street cars
Manufacturing and R&D​
- USA sourced materials with certification ensure our products are built with the best materials
- CNC machining by local machine shops with years of high tech machining experience, to meet exact tolerances
- TIG welding is performed by local professional welders with years of experience, to ensure the highest quality welds for maximum strength
- All parts are hand fitted to ensure good fit and smooth threading. Anti-seize and 3M internal panel coating applied where necessary for protection
- In-house research and development. Because SPL designs and uses their products, they can provide total support to customers
- Spherical bearings with Teflon liners, are self cleaning and self lubricating, providing high performance and long life
- Innovative adjuster design, provides quicker alignments and proper bearing centering. Tight thread tolerances for precision
- Made with pride in USA by skilled machinists/welders, using quality materials and finishes, innovative designs and R&D
Whether you're simply looking to lower your Tesla for improved stance and street handling, or looking to win your next pro or amateur race weekend, SPL has you covered.
No more jam nuts!​
Long gone are the days of fumbling with multiple wrenches to tighten jam nuts in place while trying to keep your bearings orientated correctly. The main arm is slotted to allow the use of pinch bolts and our Rotating Clamps on our exclusive Double Adjuster locks down your settings. Our Double Adjuster is machined from 4130 Chromoly and is electroless nickel plated for corrosion resistance.
All SPL Tesla Racing Suspension parts are proudly designed and built in the USA.
Control Arms/Endlinks
SPL - Adjustable Front & Rear Swaybar Endlinks - Tesla Model 3 & Model Y​
Tesla Model 3/Y Rear Endlinks have massive 1/2" FK Rod Ends to provide the highest load capacity for use with stock or stiffer aftermarket sway bars. Custom machined High Misalignment Studs offer extreme articulation capability (65deg) to prevent the endlink from binding when used with different adjustment holes on aftermarket sway bars. Our Endlinks are also length adjustable to eliminate preload on the sway bars, which can result from uneven settling of springs or uneven suspension heights from corner weighting.
SPL - Adjustable Rear Toe Links - Tesla Model 3 & Model Y​
Tesla Model 3/Y Rear Toe Links increase stability and response by eliminating bushing deflection while providing an increased range of rear toe adjustment, necessary for lowered cars or for performance alignments. Even small changes to ride height and camber will affect toe settings, and the wide range of adjustment allows you to maximize grip on a track car and extend tire life on a street car. Black Anodized and gun drilled 2024 Aluminum main links along with our 360 degree Rotating Clamp design allow for quick and precise adjustment. The Rotating Clamps are tightened with Blue Anodized Titanium Socket Head Cap Screws for easy to access adjustment, and shaves even more unsprung weight, without compromising strength.
Our Rear Toe Links feature gun drilled 2024 Aluminum center links, clamps, and clevises, along with Blue Anodized Titanium socket head cap screws and our 360 degree rotating clamp system. This combination provides superior strength, performance, durability, and ease of adjustment. Long gone are the days of fumbling with wrenches to tighten jam nuts while trying to trying to keep your bearings oriented correctly. A simple 3/16" allen key is all that is required to lock down your alignment settings!
SPL - Adjustable Rear Upper Lateral (Camber) Links - Tesla Model 3 & Model Y​
Tesla Model 3/Y Rear Upper Links greatly increase the range of rear camber adjustment for high performance track/street applications and are a must for lowered cars to meet alignment requirements. The adjustment range provided by the eccentric washer on the OEM control arm is insufficient to get camber back into proper spec.
Our Rear Upper Links feature gun drilled 2024 Aluminum center links, clamps, and clevises, along with Blue Anodized Titanium socket head cap screws and our 360 degree rotating clamp system. This combination provides superior strength, performance, durability, and ease of adjustment. Long gone are the days of fumbling with wrenches to tighten jam nuts while trying to trying to keep your bearings oriented correctly. A simple 3/16" allen key is all that is required to lock down your alignment settings!
FK Spherical Rod Ends eliminate the soft worn out bushings on the stock links to reduce alignment change in the rear suspension under hard cornering, acceleration and braking. They feature a Teflon liner to provide quiet operation, low friction, smooth articulation, and eliminates bushing deflection under load. The PTFE liner is chemically bonded to the inner diameter of the race. The liner offers a very high load carrying capacity and has greatly increased dynamic wear characteristics. The operating temperatures of the liner ranges from -65º to 325ºF, offering robust reliability for both street and track use.
SPL - Adjustable Rear Upper Traction Links - Tesla Model 3 & Model Y​
Tesla Model 3/Y Rear Upper Traction Links increase response and stability by eliminating bushing deflection under hard acceleration and braking and help to reduce wheel hop on hard launches. Our length adjustable links allow fine tuning of rear bump-steer and anti squat characteristics. These arms are designed for use in high performance street and race vehicles.
Our Rear Traction Links feature gun drilled 2024 Aluminum center links, clamps, and clevises, along with Blue Anodized Titanium socket head cap screws and our 360 degree rotating clamp system. This combination provides superior strength, performance, durability, and ease of adjustment. Long gone are the days of fumbling with wrenches to tighten jam nuts while trying to trying to keep your bearings oriented correctly. A simple 3/16" allen key is all that is required to lock down your alignment settings!
FK Bearings rod ends manufactured in Connecticut feature a Teflon liner to provide quiet operation, low friction, smooth articulation, and eliminates bushing deflection under load. The PTFE liner is chemically bonded to the inner diameter of the race. The liner offers a very high load carrying capacity and has greatly increased dynamic wear characteristics. The operating temperatures of the liner ranges from -65º to 325ºF, offering robust reliability for both street and track use.
SPL Parts - Rear Lower Traction Rods - Tesla Model 3/Model Y​
Tesla Model 3/Y Rear Lower Traction Links increase stability and response by eliminating bushing deflection under hard acceleration and braking and help to reduce wheel hop on hard launches. Our length adjustable links allow fine tuning of rear bumpsteer and anti squat characteristics. These arms are designed for use in high performance street and race vehicles.
SPL's Rear Lower Traction Rods feature gun drilled 2024 Aluminum center links, clamps, and clevises, along with Blue Anodized Titanium socket head cap screws and our 360 degree rotating clamp system. This combination provides superior strength, performance, durability, and ease of adjustment. Long gone are the days of fumbling with wrenches to tighten jam nuts while trying to trying to keep your bearings oriented correctly. A simple 3/16" allen key is all that is required to lock down your alignment settings!
Bushings
SPL Parts - Front Lower Arm Shock Monoball Bushings - Tesla Model 3/Model Y​
SPL Parts Front Lower Control Arm Shock Bushings replace the stock mushy rubber bushings with low-friction PTFE lined spherical bearings, eliminating bushing flex and reducing friction. This maintains optimum suspension geometry under load to improve handling and feedback.
Our Bushings feature FK Spherical Bearings that are self-cleaning and self-lubricating. Large 3/4" size bearing offers huge load capacity and long life. Highly precise (machined to 1/1000th inch) CNC machined 6061-T6 Aluminum bearing shells and sleeves provide an accurate fit.
SPL Parts - Caster Rod Bushings (Non-Adjustable) - Tesla Model 3/Model Y​
SPL Parts FKS Series Non-Adjustable Front Caster Rod Bushings (CRBN) replace the stock flexible rubber bushings with low friction, articulating Spherical Bearings eliminating bushing deflection and reducing friction. This maintains optimum suspension geometry under load to improve braking and handling feedback. Massive 1" sized FK Racing Bearings with self lubricating Teflon liners are used to ensure maximum performance and durability.
EAS is an authorzized SPL dealer with the entire SPL line in stock - ready to ship immediately or install at our 8000sq ft facility in Anaheim, CA.
New website, links have changed:
