After a night of charging outside is cold weather, I noticed one end of the UMC cable is split open. Had it for 8 months. Anyone else had that issue? I'll bring it in to the SC. Just curious.
Thats what happens when poor/low quality "rubber" fatigues. That is not box cutter. I deal with this all the time on Chinese scooters I repair. Its not real rubber, it's a petroleum base, or basically, more malleable. Most likely, the plastic/fake rubber was not hot enough when it was extruded. Also, more likely to happen in cold weather. And by the looks of it, OP is in Canada.Looks like a box cutter gash. It looks like it's just the outer insulation, but I would get it replaced. Electrical tape should be fine, temporarily.
Yep, that stuff is extremely pliable at warm temps, once it gets cold... Lets put it this way, had a floor mat from a Chinese scooter. At 10*F outside, I was able to toss it in the air and it shattered when it hit ground. I hope whats on the UMC isn't that poor of quality though.Yep, am in Canada. Plus I was at a cottage in the mountains. Coldest night so far this Fall.
No, another defective UMC.So I called support who directed me to my local SC. Stopped by Thursday and they swapped my UMC for a new one. Said first time they saw that. As usual, super easy and friendly staff. Was all effortless!
Hadn't tried the new UMC until today and I'm afraid I must be not doing something. I plug it in. Green light is on but the button won't open the charge port. Opened manually and plugged in, ring stays white, plug doesn't lock in and UMC doesn't charge. Tried Reset several times to no avail. Also tried both 5-15 and 14-50 adapters and sources.
Meanwhile car charges fine using my HPWC.
Is there a pairing process with a new UMC that I somehow missed?
I've gone through 15 in 2 1/2 years. Though, I finally found the problem I was having was due to charging at 40 amps every night. Once I limited it to 32 amp or less, no more problems.Another? Frequent problem?
I'm on #10 myself. Also charging at 40A. You are 100% correct, the UMC cannot take constant 40A charging.I've gone through 15 in 2 1/2 years. Though, I finally found the problem I was having was due to charging at 40 amps every night. Once I limited it to 32 amp or less, no more problems.
No, but it does happen. Call Tesla Support, they will FedEX one to you with a return label if you are further distance from a service center.Perhaps but this one was a replacement I just got from Tesla. Never charged once, let alone at 40A.
Are defective units out of the box common?
There is really nothing I need to do to 'pair' a new UMC?
Before going through all that, have you checks to see the pins are clean and there isn't something gunked up in the connecter where it plugs into the car?
Yep. Thought of that. Plug is (or looks) brand new. Nothing seems to block the connectors.
