Hi, everybody. I've figured out how to calculate EPA rated range from the two dyno test numbers (UDDS and HWFET) in the EPA document. As you might know,
@omgwtfbyobbq discovered 3 EPA documents. One was for the Model 3 and the other two were for the Model S and X.
The Model 3 EPA document has two dyno test scores: 495.11 miles for UDDS city range and 454.64 for HWFET highway range. However, we didn't know how to convert that to EPA rated range, until now.
Here are the formulas for the Model X and Model S:
Model X EPA rated range =round(73.4%*(0.55*UDDS city range + 0.45*HWFET highway range)) << start with this to test
Model S EPA rated range =round(73.8%*(0.55*UDDS city range + 0.45*HWFET highway range))
Applying the Model S formula to the Model 3 80, I'm calculating 352 miles EPA rated range. At this point, you might be thinking, yes but Tesla said 310 miles EPA. Well, that's not actually true. Tesla never said EPA range for the 310 number. Now, let me walk you through the formulas so you can see for yourself that they are correct:
Step 1: Open this 32-page Model X EPA file
here.
Step 2: Scroll down to page 6 and read the Model X 60D UDDS range. It says 267.75 miles. UDDS stands for Urban Dynamometer Driving Schedule.
Step 3: On page 7, read the Model X 60D - HWFET range. It says 276.87 miles. HWFET means Highway Fuel Economy Test.
Step 4: Apply the first formula:
Model X EPA rated range =round(73.4%*(0.55*267.75 + 0.45*276.87))
=round(73.4%*(147.26 + 124.59))= round(73.4%*(271.85))= round(199.54)= 200 miles EPA rated range
You can continue checking the other Model X trim levels in that document. The formula works for them all.
Let's try the same with the Model S:
Step 1: Open this 32-page Model S EPA file
here.
Step 2: Scroll down to page 18 and read the Model S 75D UDDS range. It says 345.5 miles.
Step 3: On page 19, the Model S 75D - HWFET range is 358.49 miles.
Step 4: Apply the second formula:
Model X EPA rated range =round(73.8%*(0.55*345.5 + 0.45*358.49 highway range))
=round(73.4%*(190.03 + 161.32))= round(73.8%*(351.35))= round(259.30)= 259 miles EPA rated range
The Model X formula works for all Model X trim levels, however, there is a problem with the Model S. Apparently, the Model S EPA rated range numbers that we know were voluntarily lowered by Tesla except for the Model S 75D. I found another EPA document
here that specifically says "Combined range voluntarily lowered" and shows the numbers before they were lowered. Using those original numbers, I was able to match most of the Model S numbers. However, besides this change that threw me off, another change was that at some point the fixed percentage for the Model S changed from 75.4% to 73.8% or maybe from 73.8% to 75.4%. It's hard to tell which one came first but I actually found those percentages in a third EPA document
here (you have to calculate them from two of the columns). I can provide more details about these last two documents if needed.
