Doug_G
Lead Moderator
At 215kW and 800A, the voltage is only 269V. That's quite a drop from nominal pack voltage; does this actually happen?
I have heard the phrase "Sport PEM" around the store...
I haven't seen the 2010 manual yet. Has Tesla actually stated how many more windings they're able to achieve in the Sport motor?
Quick freshman physics explanation:To first order, you can think about it in terms of the basic solenoid equationB=mu*n*IWhere B is the magnetic field, mu is a permeability constant, n is the number of windings per unit length, and I is the current.
So you can see if you're able to increase the number of windings, n, by say 5%, you get a 5% higher magnetic field, B, for the same current, I. In a motor that higher magnetic field means more torque, again for the same current (to first order).
DC is different from AC. RMS voltage is used in equations... 269 * 1.414 = 380 peak-to-peak. If you measure AC from the tip of the upper wave to the bottom of the trough, that's called peak-to-peak voltage. That voltage has to be divided by the square root of 2 (about 1.414) to calculate RMS voltage (root mean square) which is the equivalent DC voltage.
This is the output current of the PEM, not the input. At low RPM, the motor wants relatively low voltage/high current, and the sport PEM can deliver that better than the standard one. In fact, power draw is less than 215kW until about 40MPH, so the output voltage is even lower than you say.
So, I gather the real difference is that below, say, 55MPH you get an additional 22 lbf.ft of torque and a power curve that peaks 5MPH sooner. That's where the 0.2s improvement comes from.
The sport has a little extra kick in the lower speed range, then accelerates similarly to non-sports as you get past the (US) speed limit.
Tracks tests showed the Sport still had that same ~0.2s advantage all the way through the 1/4 mile up to top speed.
Yes, I think about sums it up. The sport has a little extra kick in the lower speed range, then accelerates similarly to non-sports as you get past the (US) speed limit.
Doesn't say much, but the PEM in the Sport seems to have its' own badge...
Also, I saw pictures of the barcode sticker on the side of the PEM where there was handwritten "Base" or "Sport" depending.
By the way, the 2.0 motors seem to have a B (for "Base") or S (for "Sport") hand written on the side.
All of this suggests that there is something different in both the motor and PEM between Base and Sport.
When they transferred motor production from Taiwan to Palo Alto, I don't know if it changed anything.
I suppose one possibility is that they could only make Sport motors now, but that is just idle speculation.
OK, so a related question is what's the difference on 0-60 times between Standard and Performance modes, for Sport and non-Sport? I'm assuming the HP/Torque specs are for Performance mode. What's different in Standard mode? Is a non-Sport in Performance mode still slower than a Sport in Standard mode, for instance?
The ethical dilemma that you pose assumes that Tesla has already figured out every possible firmware upgrade, has the firmware images ready to go, and is merely holding back so they have the option of selling upgrades in the future. That makes absolutely no sense, because why wouldn't they be offering those upgrades already so they can collect the cash now?I'm not sure there is actually any difference in the motor. The same Tesla person that said the motor is the same also said that Tesla may someday offer firmware "performance upgrades" for a price to current customers. When I questioned the ethics of such a practice, they said that there are many companies that offer after market chip upgrades for ICE cars to get better performance. Although this is true, I don't think there are any car manufactures that purposely sell "performance hindered" cars just so they can sell them an upgrade later. This practice is far more common in the electronics and software world where manufactures sell products and later sell "unlock" codes to enable features that were there out of the box but disabled until purchased. I don't fault Tesla for such a practice, it is just new for the automotive world.
It's on the order of 0.2 seconds, for a non-Sport at least.
I totally agree with your take. Basically, what you're saying fits with Occam's razor: "the simplest explanation is most likely the correct one." We know for certain that AC motors can be wound by hand and by machine. We also should be able to accept that there is a difference in performance if the windings are different. Once you accept that it is possible for two motors that appear identical on the outside, but which have different windings on the inside, to in fact be different motors ... well, I stop questioning Tesla's claims at that point. There simply is no reason to assume that they could make every Roadster perform at Sport levels and are too stupid to offer the option as an upgrade to non-Sport owners.Here's my take:
I cannot imagine that they are hand winding all the motors. Hand winding is very expensive. I can't believe they would give that away for "free".
The other option for everyone getting the same thing would be, of course, if no one is getting a hand wound motor.
Of course, I also have no idea what they are doing.
I think your original question was vague, in that it could be interpreted two ways, and thus the answer wasn't the one you were seeking.So if my non-Sport lives up to its 0-60 in 3.9 seconds spec, then in Standard mode it's 4.1 seconds?
And so my car in Performance mode is about as fast as a Sport in Standard?
Haven't you ever driven a sports car so fast that you buried the speedometer needle at the 'maximum'? It is possible for a car to go faster than the highest reading on the gauge. This is especially true with older cars, or cars which do not show anything beyond about 70 mph for legal/liability reasons. Even the non-Sport Roadster can exceed 200 kW if you trust the 215 kW specifications, and thus I just assume that the needle is pegged by the pin in the guage.Now, here's a conspiracy for you; if the Sport is more powerful, how come both power gauges are calibrated to 200KW?
