I'm just curious if they allowed a higher bitrate than the 64 with slacker. I haven't even gotten the update yet so I can't even do an ear test.
‘you can upgrade to slacker plus for $4/month. Provides 384kbps audio
Sadly no longer true for the S and never the case for the 3.‘you can upgrade to slacker plus for $4/month. Provides 384kbps audio
The Spotify app streams at 96 kbps (see here).I'm just curious if they allowed a higher bitrate than the 64 with slacker. I haven't even gotten the update yet so I can't even do an ear test.
While there is no search within the Spotify app, the global search (magnifier icon) returns results from Spotify if the app is logged in. Works well enough for me. You can also use voice commands to search.Its kinda lame without being able to search from within the Tesla app. It basically only serves as a preexisting mix tape right now.
Thank you. 96kbps is disappointing.The Spotify app streams at 96 kbps (see here).
While the app is clearly lacking in functionality compared to the phone app, I rarely have the playback issues some of you guys are reporting. I suspect this may be related to bad cellular coverage in some areas and that the app isn't robust enough in handling intermittent connectivity issues.
What the previous poster probably meant is that the Tesla Slacker client no longer has an option to increase the bitrate even if your subscription level would support it (used to be possible up to 128kbps), so using your own subscription will not increase the audio quality.I don't understand. I've been using it forever on my X and just set it up on my Model 3. You set up your account on the slacker web site, and the use those creds to log in, in the car. Slacker Plus is still an option. Works fine.
At the end of the day this is about what Tesla has to pay for the cellular bandwidth. Perhaps they'll offer a paid premium service at some point. Personally I find Spotify's 96 kbps Vorbis adequate for a car (it's also their default bitrate on mobile clients, but there the user can increase it).
Right. I was referring to the higher bitrate, which is no longer an option.I don't understand. I've been using it forever on my X and just set it up on my Model 3. You set up your account on the slacker web site, and the use those creds to log in, in the car. Slacker Plus is still an option. Works fine.
Exactly.
It kinda seems like the Spotify implementation was done as a last second rush job...
Darn it... I had posted that before I read the thread, and came across your initial post stating that, which was upstream of my post. And of course, by the time I had read your post, it was too late to edit mine.Spotify has been in the software for years
The European folks have been complaining about it having issues for those same years.
it's not new.
The only thing new is enabling access to it for cars in North America (a couple folks in NA even had it enabled in the past in various ways on earlier SW versions)
Curious why it took them so long to get it on this side of the Atlantic.
Is it just me or is the spotify app in v10 just not good? Constantly loading errors, and timeouts. The only fix seems to be two thumb salute.
I had intermittent Spotify after 32.12.2 firmware update, music wouldn’t stream if you did too many skips, would only play a single song even though there were many on the play list, would just stop streaming with the activity indicator spinning endlessly. To fix some of these issues I would go to Slacker get audio streaming again and then it would work in Spotify again. All of these issues were resolved by doing a hard reset of the car, now Spotify seems to work reliably.
Pick a song by an artist and when its done playing that song it will continue on a station playing similar songs. Its easy to do.How do you play a "station" in Spotify? All I can find is lists that never change, same lists, same songs all the time. I just want to play classic rock, 90's, edm, classical, pop, metal, etc... There is a stations tab on the main screen, but it is totally blank.
