Squeaky falcon wing doors
Discussion in 'Model X' started by Freedom101, Sep 22, 2017.
  1. Freedom101
    Freedom101 Member
    Vancouver BC
    I was fully expecting squeaky FWD when I took delivery in August. My expectations were met by both FWD. No big deal at all to me and schedule a service appointment.
    Took them in early September and to my surprise they advise they weren't going to replace any part but simply make a hinge adjustment. So they did and there was no squeak at the service center.
    The next day at home both doors started squeaking again. The squeak was shorter and quieter but definitely still there.
    Question: is there a part replacement I should be pushing for or is the adjustment (when completed properly) typically enough to fix it? Your experience is appreciated.
  2. Dr.Will
    Dr.Will Member
    Irvine
    I heard there was a part that was supposed to be replaced. My FWD just started to squeak on one side..
  3. outie
    outie Active Member
    SoCal
    Try some WD40....
    • Disagree x 2
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Which is not a lubricant but is a "Water Dispersant" (hence the "WD"). And where you would you spray a lubricant? The FW door hinge points are not readily accessible.
  5. Freedom101
    Freedom101 Member
    Vancouver BC
    This.
    Spraying WD40 on them may work but it's going to make a mess and drip all over the ceiling, seats, and floor. Not the solution I'm looking for.
    If anyone has can quote a part replacement number that may be helpful.
  6. rainforest
    rainforest Member
    Vancouver
    I had heard on the forums that it was just a simple adjustment. I have squeaks as well and they seemed to have fixed it for me. But sometimes I notice it comes back again when it gets cold outside... not sure about this though.
  7. Maximus-MX
    Maximus-MX Member
    Greeley, CO
    I had the squeaks on the left FWD. Used WD40 and it didn't fix it. Took it to sercvice center. They adjusted something. When I get it back, it started squeaking (lower noise) right there! I had to leave and they scheduled me with a ranger to come to my house and look at it again.
    The ranger told me that he has fixed many of those squeaking for good. Turns out, it only needed some special kind of grease (like a white substance). He also put it on the other FWD (preemptive strike).
    That was in May 2017. No more squeaking since then.
    • Informative x 2
  8. Magus
    Magus Member
    Midwest
    My left FWD has a squeak. One adjustment and and it has not recurred.
  9. ditzpro
    ditzpro Member
    michigan
    Took mine to the Cleveland SC after the ranger used the white stuff and it only was a temporary fix ..They told me they trimmed the plastic away from the hinges ...No problems since ...
  10. SoCal Jimmy
    SoCal Jimmy Member
    Los Angeles
    The squeak is caused by the hinges rubbing on the black plastic trim that runs along the top of the door. The fix is for them to grind away some of the plastic on the back side of it to allow more clearance.
  11. DrivingRockies
    US
    I was told they added some abrasion tape. Never heard a squeak again.
  12. nsoriano85
    nsoriano85 Member
    West Des Moines, IA
    I had the squeak and they came and trimmed the plastic on the side making the noise as well as on the other side just to prevent it from occurring.
  13. BLKTSLA
    BLKTSLA Member
    Unknown
    Cosigning with @SoCal Jimmy and @nsoriano85
    The issue is a design flaw where plastic pieces in the hinge are rubbing against each other. They trim that down and it goes away, I also recall my Tech removing a piece from the door that he said was "non-essential" that also contributed to the pieces rubbing. Either way if your Service Center didnt file/trim those pieces down then it will definitely come back....havent had an issue in several months!
  14. ryantank
    ryantank Member
    San Francisco, CA
    Is there a way to visually inspect the pieces that should be filed/trimmed, or do other core parts of the door have to be removed first? I don't have any squeaks, just what sounds like little tiny plastic rubbing noises when the door opens up. Only in a silent garage, outside you really don't notice it at all, so I'm not sure if these are normal sounds. @BLKTSLA do you perhaps have a video recording up close of your door opening/closing so I can tell if my noises are normal? Thank you!
  15. ryantank
    ryantank Member
    San Francisco, CA
    Or actually, can anyone here who has had the SC address the problem take a small video up-close of their door opening and closing so that I can hear what it sounds like? Just want to make sure my noises are normal. Thanks!
  16. Freedom101
    Freedom101 Member
    Vancouver BC
    @ryantank ask and you shall receive! So I know I started this thread but I can't get my door to squeak for the last few days (not that I'm complaining)... Not sure if it's due to the cooler temperature or what...
    So did a video on them not squeaking and also noticed I have a white substance on one side.
    I also covered my clicking rear hatch which still clicks after being replaced once:
    Subscribe here if you're interested:
    Freedom101
  17. ryantank
    ryantank Member
    San Francisco, CA
    @Freedom101 Wow, thank you for the video! That's exactly what I needed to see. Your doors seem to work quite well unless there are little noises not coming through the video. Thank you!
  18. MinionBlob
    MinionBlob Member
    Virginia
    My FW doors were serviced 3 weeks after delivery for the very same issue. It was a 2-hour repair session on each side, so, no a WD40 lube job would not have fixed it.
    Unfortunately, this repair had resulted in 2 more unsuccessful SC appointments to silence resulting squeaks and rattles somewhere inside the headliner from wire couplings coming loose, and other complications from this first repair. Now, they gave up and a brand new (black) headliner has been ordered--part availability 4-6 weeks on an Urgent order--apparently they have no stock.
    I'm very appreciative of the SC's personnel and helpful attitude in doing their best to fix the issue, but my patience is starting to wear to what would otherwise have been a very positive overall experience with the car.
    Part availability, however, is simply not acceptable in any price range, especially in a domestically manufactured vehicle. Now I understand how owners can be stranded without their cars for months left at a body shop due to lack of replacement parts.
