Squeaky fan?
Discussion in 'Model S' started by megawhizz, Aug 7, 2014.
Tags:
  1. megawhizz
    megawhizz Member
    Detroit, MI
    I've noticed a squeaky sound coming from the front of my S85 (most pronounced when standing outside the car), that seems to originate from the HVAC fan. It's quite obvious when the car is powering down. Is this normal?
    AC running audio clip
    AC shutting down audio clip
    Thanks! The wisdom of this board has been amazingly helpful in my first 2 weeks of ownership!
  2. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Just had my right side fan replaced for this same problem last week (after 1 year and 24k miles). Yours is actually worse sounding than mine. I only heard the problem on mine when it was spinning down like yours plus when the fan was running at a lower speed while the car was charging. The bearings have gone bad on the fan and your SC will replace it for you.
  3. SamGarber
    SamGarber S85 "Whale Shark"
    Philadelphia
    I have this too. I had them check it before but they didn't fix it. Will insist they listen when it powers down this time when I do service.
  4. Rockster
    Rockster Active Member
    McKinney, TX
    I have the same problem. I've arranged to leave the car with the SC one day soon for them to listen to it. I'm at 19,000 miles.
  5. Tupelo
    Tupelo Member
    Los Angeles
    My three-week old S85 with 1200 miles makes that same noise, especially when shutting down. If it's because the fan bearings have gone bad, I'd have to say they started out that way.
  6. SamGarber
    Philadelphia
    My loaner with 400 miles has it. Tech said they're still working on fix when I dropped off this morning.
  7. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    Super common. If you turn off the A/C, you will hear it. Mine did it when new, and they attempted to fix it, but remained the same. They eventually replaced the fan, and it got even worse - Squeaks even when running (not just spinning-down) and you can hear it from a block away. They replaced it again, and now I'm back to squeaking only when spinning down and it's much quieter generally. There are many discussions about this in many threads over the last couple of years.
  8. megawhizz
    megawhizz Member
    Detroit, MI
    I've had it since day 1 as well (car is 3w old). Have contacted [email protected], will post their response here.
  9. megawhizz
    megawhizz Member
    Detroit, MI
    No response from Tesla yet. How long do they usually take?
  10. CarlK
    CarlK Active Member
    SF Bay Area
    I hear it when something is turnning off but it does not really bother me.
  11. wamochi
    wamochi Member
    San Diego, CA
    i had the "chirping" hamster wheel squeak upon delivery too. took a video clip of it and showed the local SC and they scheduled a repair and replaced both AC condensers and it's quiet now. mine was incredibly loud and obvious to anyone in the garage or passing by in a parking lot.
    it is normal to have some noise upon shutdown when the compressor is winding down, but a loud hamster wheel squeak is not normal.
  12. hotwire
    hotwire New Member
    Dallas
    I'd just assumed the squeaking during shutdown was normal, but it sounds like I've got the same issue. I'll also be contacting my local SC once I capture that audio as well.
    Thanks to everyone so far for confirming.
  13. invisik
    invisik Supporting Member
    Minneapolis
    Yeah same here, Service Center replaced the condensers, the massive squeaking is gone and the whole thing is just generally quieter (and I don't have the blanket yet either)....
    -m
  14. megawhizz
    megawhizz Member
    Detroit, MI
    Tesla called me (at 9:50pm!) the day after I posted this and left a message saying "we heard you were trying to reach us - please call" - wonder if they monitor these forums?
    They forwarded my concern to the closest SC (no local SC in Detroit). Last I heard (8/20) the rep was going to play my audio clip to a supervisor, and get back to me.
    I'll keep everyone posted when the issue is resolved.
  15. maxwells
    maxwells P85 43796
    San Francisco
    Same experience with the noise and condenser replacement at Burlingame SC. All good now.
  16. Rockster
    McKinney, TX
    They replaced my driver's side condenser fan yesterday. No shroud or soundproofing is mentioned on the service invoice yet the AC seems considerably quieter. I still hear slight hamster wheel chirping on shutdown, but it's much more subtle. The biggest difference is that the passenger and driver side floor no longer feels like a vibrating motel bed when the AC is in non-Range mode.
  17. SanCarlos
    SanCarlos Member
    Bay Area
    Palo Also SC replaced both the condenser fans yesterday. No more shriek when they shut down.
  18. trbeals
    trbeals Member
    United States
    I have the squeaking-on-shutdown (and have had it from when I first purchased the vehicle), but otherwise it doesn't bother me (it's not particularly noisy during normal operation). Palo Alto SC told me this was normal, although I'm not convinced. Should I be worried that the fan is going to die prematurely?
  19. megawhizz
    megawhizz Member
    Detroit, MI
    Issue Resolution: SC lubricated the fan, squeak is gone. They said that they will replace it if the noise returns.
  20. rainman50
    rainman50 Member
    Midwest
    #20 rainman50, Oct 27, 2014
    I just got my P85, last day in Sept 2014. Just started to hear the squeaking sound under the hood. It can be there when the compressor is on and especially when the fan winds down to turn off. I'll keep an ear out for it and see how often it happens.
    Also, the reason I responded to this particular post was that I to notice a slight vibrating side floor. So the compressor fan fixes that vibration?
    Can a ranger fix that problem or does it have to be fixed by a SC?
