Well, more like a creaking popping sound as the sway bar turns far enough in the bushing to break the grab the rubber has and slip to the rotational low energy point.
Took several hours with the front wheel off jacked up and moving the car up and down on one corner before I finally tracked the popping to the actual sway bar bracket.
So does anyone know when before this starts happening, is it because the rubber bushing doesn't slip acting like the rotation bushing one one of the control arms? Or does the sway bar rotate freely within the bushing and it eventually starts to have less and less slip until the rubber grabs?
I suspect the latter since that's how sway bar bushings normally work.
The bushing bracket releases on one end so you can pry it open a little. Looking at the FSM procedure for removing the sway bar, you have to slide the bracket and bushing off the end of the sway bar, but it won't budge right now because the rubber is really grabbing the sway bar even after I pry the bracket open a half inch.
So tomorrow I'm going to use an 18 gauge grease needle(very thin) and silicon grease in a 6000 psi grease gun and inject grease between the bushings and sway bars while holding the bracket open as much as I can get without exceeding the brackets closed side spring rate.
Has anyone else had this issue and what did you do to fix it? The sound only happens when going slowly and going over something where the wheels don't stay level with each other. So not during normal driving. It is driving me nuts though.
