Squeaky Windows
studioloft
Gavin
Nov 4, 2019
77
72
Norwalk, CT
Hello everyone,
I have always had squeaky driver and passenger windows on my Model X and figured I just had dirt in the edges or I was doing something wrong. Yesterday I met up with two other friends that own a Model X and we found that all three of us share the same issue. This is the first car I have owned that has this issue but apparently it is much more wide spread than just my car.
Has anyone on the forums experienced this issue or implemented a solution?
Varmint
58
52
Spokane, WA
I’ve recently got a tint and mine started squeaking. Some say use silicone spray and some even say WD-40, but both of those sound like messy options. I ordered some dry graphite in a spray can and will let you know if it works (well, short-term at least).
Ames
659
376
Abu Dhabi, UAE
I had this and found it be dirt on the inside of the window at the bottom in the area that is normally concealed when the door is open. I solved it by sitting inside the car with the doors closed and windows fully up, and cleaning the bottom strips of the windows. YMMV.
jschlock
New Member
Nov 6, 2017
2
0
San Mateo
2019 X and same with all windows; squealing when operating (my wife shakes her head in disgust ). During wet weather they are okay. Plan to try silicone spray; any ideas?
ShawnA
873
649
Edwardsburg, MI
Hi All,
My passenger window squeaked horribly the day we picked up the X.
From other suggestions here I use "Gummi Pflege Stift."
It is a German rubber care treatment.
It comes in a bottle with a sponge applicator on the end of the bottle
like some shoe polish.
It is wonderful and quiet.
It is available at Amazon.
It helps to prevent the windows freezing to their seals in the winter.
It also works wonders on the rubber foam weatherstripping on the Falcon Wing Doors.
Enjoy,
Shawn
Reactions: Billstickers
ek993
238
128
CT
2018 X. Squeaked horribly when new - and window struggled to close as seals were way too tight.
2 years in and they are fine now seemed to have bedded in.
Truthman
27
4
Sacramento
Hello everyone,
known “characteristic.” If you clean and lubricate the belt molding and window, the noise will go away temporarily. However, it will come back. No permanent rectification.
