Just curious, if you can swap out a SR+ battery and put a LR battery in.
Questions to consider are:
1. Would the battery from the LR bolt straight in , or does it totally need new mountings to screw / bolt to
2. Integration into the SR+ computer - will the SR+ accept the larger range battery, or would it need upgrades, and if so what are they.
3. Controller -- replace ?
4. Charging hardware?
5. Wiring harness - ok as is?
Thanks for reading.. questions are because at $23, 000 aud more for the LR AWD, it might be better path , SR+ , then upgrade from a wrecked LR when one becomes available. Shocks etc are they the same , suspension wise , for the two variants , given the extra weight of the LR battery and extra front motor etc ? (about 200 kgs )
Other possibility is to wait for a second hand LR RWD to come up second hand - that would mean no Tesla for a long time.
