SR / SR+ owners really need Boardman OR!
acarney
2,326
1,385
Richland, WA
These kinds of things are always set up as a hybrid system, where they have another heating element they can use when the outside temperature is too cold. My house has a heat pump system with gas furnace backup. The cutoff point is set I think at about 39 degrees.
I don’t believe the Model Y has that, or at least no information has come out on that. Elon mentioned it had a “special mode” that allowed it to “short” out and run in a less efficient mode to generate heat in high demand cases (heat through some other method compared to how a heat pump normally works) but didn’t go into detail. I can’t imagine it works as well as a dedicated 3kW or 5kW resistance system... but maybe? Just a little concerned since the car shipped after winter was larger over. The heat pump in the house is largely useless in periods of deep cold in the winter (we occasionally get 10 to 25 degree days and nights maybe 20 or 30 times a winter). In fact, the heat pump alone isn’t able to keep up with the demand even when at the set point without occasionally kicking in resistance heating. (Very old house, poor insulation. But then again, a car has pool insulation & a lot of glass radiating away that heat!)
Reactions: Rocky_H
Rocky_H
5,848
6,684
Boise, ID
That would be insane. I assure you they would not have been so stupid. It must have an alternate heat method it can use as needed.
So...resistive heating, like I said.
Resistive heating is not complicated and hard to do badly.
There are large portions of the year, though, where you want a little heating because outside temperatures are in the 40's or 50's, and heat pumps excel in those kinds of conditions and are massively efficient.
Don't panic about colder temperatures. I am certain there is resistive heat that will handle it in those conditions.
acarney
2,326
1,385
Richland, WA
Well from the comments Elon made it sounds like it’s built INTO the heat pump. So while resistance hearing isn’t hard to do, sounds like Tesla figures out a way to make it complex...
Rocky_H
5,848
6,684
Boise, ID
Ah, well, yes, Tesla has shown that they have a penchant for complicating things. "Let's make car doors, but built in separate parts, with motorized hinges in between and proximity sensors to detect through sheet metal!" :(
Long Ranger
31
78
Seattle
Yep, but it’s a pretty good design. They have a patent on a low temp heat pump without a resistive heater. Basically they capture the waste heat from the drive motor, battery, and cabin. And if those are all cold, they can run the compressor and blower motors inefficiently to produce heat just like they do with the drive motor for Supercharger preheating.
US20190070924A1 - Optimal source electric vehicle heat pump with extreme temperature heating capability and efficient thermal preconditioning - Google Patents
Reactions: IdaX and ReddyLeaf
acarney
2,326
1,385
Richland, WA
And I wonder how fast you get heat on ice cold days when the car has been sitting in a parking lot or something. I know you can precondition, and I try to do that as much as I can, but right now Model 3 can blow pretty hot air within like 30 seconds. When I precondition for supercharging it starts like 20+ minutes away from the supercharger :p
Misternt
73
100
Oregon
Well with the newest info from Tesla the Boardman supercharger no longer shows as coming soon. The east side of oregon is really missing superchargers.
Rocky_H
5,848
6,684
Boise, ID
I doubt it has really been removed. People are flipping out this morning from a few pins going missing, and thinking that it's on purpose. It's some screwing up with database updates.
acarney
2,326
1,385
Richland, WA
Could be, and I'll keep my fingers crossed.... but I thought most missing pins were existing superchargers (who knows why) and pins that were adjacent to recently opened superchargers...
It could be that Boardman just doesn't have an ETA and if that value was left empty maybe the pin didn't populate or something?
