I'm a new Powerwall user in Phoenix, AZ. I just started using SRP's Time-of-Use Demand Plan (this is E-27 plan, not the average Demand plan E-15). This plan will charge regarding on-peak time demand (kW) which is measured in 30-minute interval. For example, in 7pm-7:30pm, if 10 minutes grid power demand is 3 kW, the other 20 minutes grid power demand is 0 kW, then demand for this 30-minute interval is 1 kW. SRP will charge by the number of demand. Yesterday is my first day to use this plan, I found the demand measured by SRP is huge different with Powerwall app.
The first chart below is SRP Demand data, it shows the demand on 7:30pm-8:00pm is 2.6 kW. The second chart is SRP Usage data, it shows usage between 7pm-8pm is 1.5kWh. Red bar means on-peak time.
But Powerwall data (both graphic and downloaded spreadsheet) show grid demand in this time period is 0. All demand is loaded on Powerwall battery rather than grid. The screenshot below is from Powerwall app downloaded spreadsheet. The highlighted rows are time period 7:30pm-8:00pm (please ignore the '-07:00' at the end of each time, I don't know what's that mean). This spreadsheet shows in this period demand is all on Powerwall, grid demand is always 0. It's super weird SRP data is 2.6 kW. SRP will charge me on this demand number, and demand charge is quite expensive.
The same situation also happened on 7:00am-7:30am. SRP data shows demand is 1.2 kW, but Powerwall app shows 0 demand on grid.
In the on-peak time yesterday, I set Powerwall Self-Powered mode (Back up reserve was set 10%). So I don't think it used power from grid, since Powerwall has enough power at that moment. I don't know where the problem is (Tesla side or SRP side). This situation makes me have no confidence at all to use Powerwall in on-peak time. Does anyone have similar experience? Any thought is welcome. Appreciate it.
I have one Powerwall+ with firmware version 21.44, app version is 4.3.1 on Android. By the way, I got "Go Off-Grid" button showing up in the app today, I tried to enable the off-grid mode, it doesn't work properly. Once click that button, the power is cut off for one or two seconds, then grid is connected back. Powerwall never works on off-grid mode. There's just around 0.3 kW load at the moment when I tried it, so it should have nothing to do with the load. I'm not sure if this is related with the demand measuring issue I talked above.
