Now a more theoretical question. What is the benefit of staggering the tires, especially for AWD. Also with Tesla monitoring the traction and sends out warning notice that cannot be removed, I would be more hesitant to touch the tires.It is safer not to rotate tires because there will be a time when the tires need to re-seat to have the best grip and full tread on the road, somewhat compromising handling temporarily after rotation. It is more economical to rotate tires, and may lengthen the tread life. Swapping tires left to right and right to left seems even less beneficial unless you are making more right or left turns or cornering more one direction.
In the case of staggered tires, if the tread depth is wearing equally on an axle, why would you bother swapping the sides with each other? BMW used to recommend not rotating tires for the safety reason. If you buy tires primarily based on their tread life and economy, and not on their handling, you might wish to rotate your tires.
I have never been impressed with the level of knowledge of people at an SC.if you do not rotate them then the right front will wear out quicker than the left requiring an early tire replacement of both front tiresI specifically asked this question at the local service center and they told me not to rotate the tires for the refreshed S, not even swapping sides.
We also have to consider wheel alignment vs. normal wear and tear. If the wheels are misaligned, rotating tires will even out the wearing. A lot of folks will get an alignment right after tires are replaced. I hate to see one side has good thread and the other needs replacement and I must replace them both. So, rotating them to even out may not be a bad idea.I have never been impressed with the level of knowledge of people at an SC.if you do not rotate them then the right front will wear out quicker than the left requiring an early tire replacement of both front tires
I would do what the manual says.
Why is front right wearing out quicker?I have never been impressed with the level of knowledge of people at an SC.if you do not rotate them then the right front will wear out quicker than the left requiring an early tire replacement of both front tires
From what I have read, in left-hand drive cars it is due to shorter radius right hand turns, and road camber which puts more weight on the right tire.Why is front right wearing out quicker?
Any idea how many miles on the tires we are talking about. If I get 20,000 miles from a set of tires, I am considered lucky.From what I have read, in left-hand drive cars it is due to shorter radius right hand turns, and road camber which puts more weight on the right tire.
My 2022 MS LR comes with Pirelli P-Zero which I consider them as high end tires. The issue is MS is heavy car. If they put on Summer tires which have soft compound, they wear out quickly.My MS got 20,000 on the first set. My tire guys said it was mostly because the car came with low quality tires. Apparently a common tactic to save a few bucks. Amaxing how cheap Tesla is on expensive cars.
Mine were Goodyear Eagel Touring, no mileage warranty.My 2022 MS LR comes with Pirelli P-Zero which I consider them as high end tires. The issue is MS is heavy car. If they put on Summer tires which have soft compound, they wear out quickly.
BandedPanda,Michelin Pilot Sport 4 on my 2020 LR and the outside wear is slightly higher on the fronts.
A little over 15k...I hope to get around 25k from them. I don't think they are staggered but I'll have to check.BandedPanda,
How many miles you had on the tires? How many more miles you expect to drive before replacing?
Thanks.
Nope, not staggered and the Michelin warranty is 30k but I'd be surprised if they last that long.A little over 15k...I hope to get around 25k from them. I don't think they are staggered but I'll have to check.
Thanks. I have never attempted to claim tire warranty due to premature thread wearing. Just not worth the fight. A new set of tire every 2-3 years is reasonable.Nope, not staggered and the Michelin warranty is 30k but I'd be surprised if they last that long.
