Stalk Button Now Disengages Auto Pilot
Discussion in 'Model S: User Interface' started by 1NJ85D, Feb 20, 2016.
  1. 1NJ85D
    1NJ85D Member
    Scotch Plains, NJ
    I dont remember observing or reading about this before.
    I'm on 2.12.22 but this could have changed in a prior upgrade.
  2. .andrew
    .andrew Member
    Gilroy, CA
    It's not new
  3. commasign
    commasign Tesla Superfan
    Davis, CA
    That's how I always disengage autopilot.
  4. tstafford
    tstafford Supporting Member
    Nashville, TN
  5. green1
    green1 Active Member
    Calgary, Alberta, Canada
    That's the whole reason the button exists. ..
  6. AWDtsla
    AWDtsla Active Member
    NE
    Not so clear when there are multiple ways to disengage. User interface design failure, IMHO.
  7. RDoc
    RDoc S85D
    Boston North Shore
    Originally the stalk button turned ACC off completely. There was a notion of ACC being off, on, disengaged, engaged. One reason for an off setting was to allow resetting the saved speeds, turn the system off, then back on, much like a power cycle reset. They gave up on the off/on state so the button is now superfluous.
  8. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    Yep. At one point I (and several others as well) were advocating for the stalk button to be a mode switch to disable autopilot and bring back the large speedometer and power meter in the center of the the IC, like we had on the 6.2 software (or as on non-AP cars). That suggestion to Tesla seems to have fallen on deaf ears, not surprisingly.
    (Why yes, I'm a little bitter about this, why do you ask?)
  9. AWDtsla
    NE
    The large power meter was awesome btw. I've only gotten time to really experience it on loaners. My feeling on what happened is they brought a talented guy in a long time ago to clean-slate the entire UI, and it was a pretty good job. Everything since that has been kind of hodge-podge. Features just duct-taped on without thought as to how they fit into a driver's usage. Like the stupid heated steering wheel control.
  10. Electroman
    Electroman Well-Known Member
    TX
    And the absence of a customizable digital clock that is easily readable.
