The Roadster re-scales the reported battery state of charge depending on which mode you're in. If you were to charge fully in Standard mode, it says 100%. Then switch to Range mode, and you're at, um, a bunch less (80% I think). I forget the number. The actual SoC percentages are shown in the logs. On my car, standard mode stops at about 83%, range mode at about 94%. There's a similar re-scaling that occurs on the discharge end of the curve, with standard mode hiding (or range mode unlocking) the bottom about 10% or so.
The range reduction that occurs after things settle is normal. I presume it's a result of the cell balancing that goes on, though yours seems a bit more dramatic than mine. Right now I'm charging to 163, and it settles out to about 161. CAC is 136.8. I had one episode after driving a long distance for the first time in a number of years, and was range charging from a 120v outlet for the drive home. The car stopped charging with a severely LOW Ideal range estimate, something in the 180's. Then, after balancing, and while I was trying to figure out how I was going to limp home, the number crawled back up the expected value of 212. So, it can work both ways.
