Standard suspension - New springs?
Discussion in 'Model S: Driving Dynamics' started by Meringdal, Sep 28, 2014.
  1. Meringdal
    Meringdal New Member
    Norway
    Hello. I wondered if anyone has lowered their Model S yet, with new springs?
    I´ve talked with H&R in Germany, and they are still testing out new springs for this car. Has anyone found someone selling aftermarked springs which loweres the car a bit?
  2. jerry33
    Texas
  3. rtz
    rtz Member
    United States
  4. QwiksilverA4
    QwiksilverA4 Member
    san jose
    problem is they dont have a set from us to give them. they need 11 points of data to process them.
  5. 3mp_kwh
    3mp_kwh Active Member
    Boston
    Find a machine shop that will cut a precise additional strut grove(s) about 1.25" lower (in back, 1" in front), and use the same springs. If you do this, just be aware that the vertical travel of the suspension will stay the same when you fill the car with stuff. In other words, weight capacity goes (probably ~150lbs) down. The after-market coils may factor this in, and either be a higher spring rate or be progressive.
  6. QwiksilverA4
    QwiksilverA4 Member
    san jose
    Where would one find the "C" clamps to go around the grooves.
  7. 3mp_kwh
    Boston
    You would use the existing "circlip", that is already clinging to the strut body (just move it down). Bilstein, in Poway, CA, does the groove service, but only for after-market shocks. I don't mean to make it sound like all machine shops can, or will, do this. Many don't like getting into limited piece work jobs, which is why "a friend" helps.
  8. smilepak
    smilepak Active Member
    Eastvale, CA
    You want to lower the MS? Isn't low enough? I'm having a hard time going over bumps our out of parking lot with angle ramp as it is....
  9. QwiksilverA4
    QwiksilverA4 Member
    san jose
    my car is high as hell!
