Knightshade
Ya'll are clowns rofl
I'm LITERALLY giving you what I've encountered.
IDGAF if you believe me or not with your logic.
Again, not logic, science.
Basic metallurgy and physics.
You don't have warped rotors, because non-defective properly installed rotors don't warp in the first place-- per sources you've been given including people who design, engineer, and sell brakes for a living that are used to stop at far far higher speeds than you're discussing.
And they certainly don't warp from a stop from 10-15 mph which would generate very little heat no matter how hard you applied them- and nowhere near the amount needed to warp iron.
Your story is not physically possible
Now, it's certainly possible you incorrectly THINK you have warped rotors, but instead have the uneven pad transfer described in the Stoptech white paper I linked to, and you obviously didn't read (or tried to and didn't understand).
But that ALSO wouldn't be caused by a single 10-15 mph stop.
That's a braking heat calculator.
Throw in a 4200 lb car, with 76lb rotors (roughly the stock model 3 rotors total weight), at 15 mph.
Increase in brake temp is... 5.3 degrees.
You're claiming you "warped" iron rotors with 5.3 degrees of heat.
Your story is not credible
