Yup. I used to get 12 mpg on the run to the station in winter. Way below the 'expected'That's the same problem with petrol and diesel cats too, short trip when it's cold vs the same trip when it's warmer.
It's a guess based on a guess. Been discussed lots of time. Generally when trying to figure out if you are losing energy somewhere then its best to use the %. That's just based on one guessIf the stated range of the RWD is 305 miles but the real world range is ~200 miles:
Is the range shown on the UI screen based on the 305 figure or the real 200 mile figure, or something else?
Sign up for the free Teslafi trial and I'm pretty sure someone will have a look at you data and tell you what is going on. Although it sounds like you're doing a lot of short journeys, it's best to check if you have concerns.Wouldn’t know where to start with that energy page in the car.
It's based on the EPA rated range, the RWD should display 273.It's a guess based on a guess. Been discussed lots of time. Generally when trying to figure out if you are losing energy somewhere then its best to use the %. That's just based on one guess
When Tesla state that the provided home charger (13 Amp plug) will charge at 10-11 mph, is that based on the 305 mile range or the 200 mile range? in other words, would it take 30 hours or 20 hours to fully charge from 0%?
OK that makes sense - thanks @Mrklawneither
stated range on the dash is based on the US EPA rating. Its a straight % battery conversion based on (checks..) 272 miles with 18" wheels. so it'll go down 2.72 miles for each 1% battery you use from 100%. Doesn't take account of how you drive at all.
It is mostly useless to use for range - tap it to switch to % and its a more meaningful measure. % use will vary but unless you're driving really fast, estimate around 2 miles per % or 20 miles per 10% and it'll be about right - bit less if you're doing 80
The energy app/tab does take account of how you drive, you can set it to check based on the last 5/15/30 miles (something like that) and it'll show average energy and predicted range if you continue to drive like that and have a route planned in on the satnav. Often if I'm sitting with autopilot on the motorway you can see that predicted range go up as your driving is stable over time
Basically it takes around 4hrs for 40%-50% in a 7Kwh standard home chargers. Assuming the battery is around 20% (as we normally do not drain it below that level) - you will have around 60% - 70%charge in 4hrs which will hypothetically translate to 180 - 200 miles in the new SR or 162 - 180 miles in the 2021 SR+. How many miles you will get in that 60% is anyones guess but definitely around 120 miles!OK that makes sense - thanks @Mrklaw
I presume that the same logic holds for the home charger then, the 10-11 mph charge rate is probably based on the 272 range figure also. This means the real world charge rate for this charger is more like 7 mph. So to recharge 100 real miles would take about 14 hours - I can live with that. Most weeks I only drive around 100 miles.
When they say your full tank of petrol gets you 700 miles and you get less than 500 miles.ICE cars sell on MPG not range, BEVs sell on range. Painted us into this corner of misunderstanding.
If they sold BEVs on miles/kwh based on WLTP and maybe a range in brackets or a 'fuel tank' size, that would help. BMW and some others I think provide estimated efficiency as well as range figures for their cars.
You tell me its 4 miles/kwh urban and 2 miles/kwh motorway (do they call it extra-urban or something strange?) then that helps me as a buyer understand the car is not going to go as far on a tank on the motorway. I know that already on an ICE but you just ignore it because you can fill up so easily.
Winter definitely reduced to 150-170 miles, Summer 240- 260 max but obviously influenced by average speed, acceleration etc.Agree with this
Yes I’m also seeing 1% per 2 mile range
So this is generally norma yeh?
EPA on the screen and WLTP on the website. Probably to keep the Europeans happy.It's based on the EPA rated range, the RWD should display 273.
LR during the winter does 200+ miles easily
Be wary of basing a conclusion on one single data point! Another similar distance journey could give a different result (positive or negative). (Wind, rain, gradients, temperature, traffic, night/day, drive style). Nevertheless, congratulations on your first lengthy trip.
exactly.While correct, he used 55% of the battery to do 150 miles at 4C. It would take some serious efficiency loss to drop below 200 in real world range on that trip.
The in car nav knows what it’s going, if anything is a bit cautious (IMO) and takes gradient into account. The U.K. generally just isn’t that hilly or gets that cold.
I should have been clearer, I was talking about using the 2.7kW 13A plug charger that comes with the car. My average mileage is only around 100 miles per week so I am contemplating just using the supplied charger initially. I am getting some building work done beside my driveway later this year so would need to move a charger if I installed it now, so will (maybe) get a 7kW charger installed during/after the building work. I was just making sure that using the supplied 2.7kW charger would be feasible, at least for a few months.shoudln't take that long. Assume RWD is around 57kwh usable, charging with a 7kw charger would be about 8 hours. Add 10% for charging losses and maybe 9 hours? Thats 0-100%.
on my SR+ I could usually rely on about 50% charge during my octopus go 4 hour off peak window
This is the problem of making assumptions. Maybe your part of the UK is not that hilly! The cocnlusion made a general statement that would apply to all trips ... I'll wager that that there are occasions when 200 miles in a LR will be a bit of a squeeze and others when it's a breeze (I should be a rapper really).
exactly.
55% to cover 150 miles @70+ mph
If keep it under 70 - that would be even better.
and I have 1 data points because I got the car for 2 days only...
