Stats App no longer turning on my AC
I’ve been using the stats app for many months and it’s worked flawlessly. Maybe a month ago, when I told Siri to, “Cool my car” it responded with, “Shortcuts will continue with your request.” That wasn’t surprising because it always relies with that response once but The second time I gave the command (which is usually when it works), there was a long pause and then it just replied with the same thing as the first time. I tried re-recording the command in Stats and it stated that it already existed but I re-recorded it anyway. Same response. Has anyone else been having this problem?
Reactions: Phlier and Watts_Up
WilliamG
Hinge Fanatic
Apr 20, 2019
6,717
10,608
Seattle, WA
Things got borked with the 2019.32 update. You need to remove the commands from the Shortcuts settings on your iPhone and re-record them. I had the same issue.
Reactions: Phlier
