Hi all,
Looking for some help here. Started the install on the Stealth hitch today. The hitch install itself is fairly easy and straight forward. The wiring I have a few questions.
So it seems that my car has the opening for the hitch below the bumper and also has the wiring harness as well (see pics)...
It looks like the hitch harness is some proprietary connector and a 3 connector adapter to the standard 3 + 1 ground wiring harness (but missing the +1 ground). There are no metal connectors inside the connector that looks to be the standard type but there but that is an easy solve to just remove the proprietary harness and slap on the new, standard one.
I am trying to find what wire does what, but just getting stable reading from the red and small yellow at 12-14volts. Blinkers don't translate into voltage variation and the black doesn't seem to do anything. Had my wife put the car in Drive and test blinkers, but not seeing differentiation (unless I am doing something wrong). Pretty sure the Red is constant voltage (even with car off, reading hot).
Anybody have some insight? I really don't wanna run the Stealth hitch wiring all the way to the front and tap into lights when everything seems to be already run for the car via factory.
Thanks.
Thanks.
