SteamCar Challenge
Discussion in 'Off Topic' started by malcolm, Aug 15, 2008.
Tags:
  1. malcolm
    malcolm Active Member
  2. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
    They seem to be using the challenge to draw attention to alternate fuels, so I'm willing to cut them some slack.
  3. tonybelding
    tonybelding Active Member
    Hamilton, Texas
    Steam powered cars were once quite popular, holding their own against gasoline and electric cars in the marketplace.
    When they finally died out, it was more due to a combination of unlucky events rather there being any serious problem with steam technology.
  4. Chris H.
    Chris H. Member
    Canada
    " ~23 cups of tea per second" - Sign me up! :biggrin:
    I bet TJ would be interested too!
    All joking aside, this might be an interesting technology if you could integrate a solar-thermal water heater to generate the steam, instead of using LPG. I suppose you could keep some LPG on board as a backup on those cloudy English days... :smile:
    Malcolm, how do you find this stuff?
    All the best,
    Chris H.
  5. malcolm
    #5 malcolm, Aug 15, 2008
    I decided to summarise the typical Finkenbusch comment by inventing one: http://www.teslamotorsclub.com/11228-post24.html
    Pointless of me really.
    dpeilow had just posted about the London to Brighton car rally, so I just googled steam car.
    But anyway, it just seems to be an exercise in replacing one type of heat engine with a moderately more efficient one.
  6. dpeilow
    dpeilow Moderator
    Winchester, UK
    I thought it was interesting that the guy thought the turbine design wouldn't be all that practical for road cars because of the porr ability to accelerate/decelerate. That may be true, but could it form the basis for a series hybrid?
  7. malcolm
    #7 malcolm, Aug 15, 2008
    Bit more info:-
    At 25ft (7.6m) long weighing just over 3 tons and using a ton of water every 25 minutes the British Steam car is no ordinary run about. When the car is moving the 40 bar water pressure is maintained using compressed air to fill 2 70-litre hydraulic accumulator bladders. The boilers contain more than 1.86 miles (3Km) of tubing and are insulated with advanced ceramic-and-silica cloth. The burners develop three megawatts of heat. The water boils at 250-degree C because it is at 40 times atmospheric pressure; this is called 'wet' steam. It is then super-heated to 400 degree C 'dry' steam, which is directed down the car via heavily lagged pipes and two industrial steam valves, into a two-stage turbine. The steam is injected into the turbine at more than twice the speed of sound and the turbine spins at up to 13,000rpm. The turbine then drives the rear wheels crown wheel and pinion reduction gear.
    The machine actually runs for less time than it takes to start. It takes eight minutes to get going and has enough fuel, compressed air and water to run for three minutes - the record can be achieved in less than two minutes running time.
    British Steam Car Challenge
    (click the link on the page to Latest Press Release)
  8. Chris H.
    Chris H. Member
    Canada
    Malcolm,
    I was just about to point out some of the same shortcomings, but you beat me to it... :smile:
  9. doug
    doug Administrator / Head Moderator
    There's a whole subculture growing based on the fantasy that steam technology never did die out. (Or is it that the tech age evolved along with the industrial age, it's never quite clear.)
    Steampunk - Wikipedia, the free encyclopedia
  10. vfx
    vfx Well-Known Member
    CA CA
    I already posted a steampunk bike here.
    http://www.teslamotorsclub.com/off-topic/1249-steampunk.html
    There are parts of the culture that I embrace. Not all mind you but I do like exposed gears and old mechanical solutions for problems. Not into the brass, just the rust.
  11. TEG
    TEG TMC Moderator
    Don't forget the movie Brazil...
  12. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
  13. malcolm
  14. vfx
    CA CA
  15. dpeilow
    dpeilow Moderator
    Winchester, UK
  16. vfx
    CA CA
    Shouldn't the record be 143-ish, not 139?
    oh yeah,
    yaa.
