Steep Driveway - Help Please
Discussion in 'Model 3: Driving Dynamics' started by LovetheM3, Jan 13, 2021.
  1. LovetheM3
    LovetheM3 New Member
    Seattle, WA
    Looking for help and input from fellow owners and enthusiasts. Have a steep driveway into garage and every entry scrapes the bottom of our model 3. Lately we've added 2 Vestil speed bumps and 2 Pyle ramps but still with no success. We've played back and forth with positioning and tried this over and over again but still no luck. Here's the latest video with what I think is the best position so far. Looking for ideas and input from those who might have faced similar. Video clip can be found here. https://photos.app.goo.gl/dkfChjHBVanTSd8WA VID_440461022_134206_790_exported_9960_1610564545109.jpg
  2. ShamDeluxe
    ShamDeluxe Member
    Colorado
    Wow, that is definitely a bummer. Outside of shaving it down, via repaving, I don't know what you can do more than those curb ramps. Maybe somehow get the curb ramps put permanently in-place closer to the hump?
  3. LovetheM3
    Seattle, WA
    Turns out we ended up with a solution to this. Drive up on the right side of the two car driveway, and just before the front wheels crest this angle change, swerve left -- and enter the garage diagonally, crossing this crest/peak at a steep angle. No scratch. No scrape.
  4. papab
    papab Member
    colorado
    It looks like your bumps are too close to the corner of the concrete. Try putting them a wheelbase apart and centered on the hump. You may need more of them. The solution may be expensive, shave down the driveway, or buy a Y. Is that a standard 3 or performance?
  5. designrs
    designrs Member
    Jacksonville, FL
    Maybe sheets of thick industrial solid rubber mats... about 1” thick that do not compress. You could stack them as needed and experiment until you get the right setup.
    Even if you had to call a professional installer to cut the mats it would be worth it. They are probably heavy and require experience and equipment to cut and position.
  6. LovetheM3
    Seattle, WA
    Thanks for the comment. We were ultimately able to find a resolution -- that is Drive up the right side of a 2 car driveway, and swerve left just as the wheels crest this angle change. The result was entering the garage diagonally but no scrape, no scratch. Also doing this with no added luggage or passengers.
    For the record this was the model 3 dual motor long range. Stock 18" wheels. 2019 model.
  7. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    I've seen some recent new homes with Wrangler Only driveways... you have to wonder what the builder is thinking other than profit...
  8. SabrToothSqrl
    PA
    wow, that sucks. I remember when I built my 2nd Jeep on 35" tires, I went house shopping, and required a 7' garage door.
  9. designrs
    designrs Member
    Jacksonville, FL
    Diagonal is generally the preferred technique for ground clearance. Your situation appeared beyond that. Glad you found something that works!
  10. designrs
    designrs Member
    Jacksonville, FL
    In what area are these Wrangler Only driveways advertised?
    Even here in the flatlands of Florida, we are seeing many houses with two garages. The first garage is the usual spacious two-car garage, and a second driveway area accesses a single-car sized garage for golf carts or other recreational vehicles.
