"Steering Assist Reduced"
Discussion in 'Model S' started by MileHighMotoring, Sep 30, 2016.
Tags:
  1. MileHighMotoring
    Parker, CO
    Drove the car for ten minutes, parked, and then got this error. There was no power steering at all, so it was incredibly difficult to drive at low speeds/from a start. The parking sensors also didn't work. Was told to power cycle the car for five minutes, that didn't help.
    I suspect this is part of the electronic gremlins that plague my car, that there are apparently no solutions for. The handles still close on my hands every day, the infotainment system fails on me frequently, etc. I was told it's a "memory leak" with no solution. I have emailed Corporate, Elon Musk, etc., not even a reply much less a solution.
    I'm not sure what I can do - there are no other places or people to talk to. I just have a car that doesn't work right and no fix forthcoming.
    I'm bringing the car in tomorrow, they said they can get to it in a few days. This, I think, will be the fifth time my car's in the shop for unscheduled problems in 1.5 years.
    • Informative x 3
  2. cynix
    cynix Member
    Sydney, Australia
    Last time this happened to me (intermittently, together with AP being unavailable), I brought the car in and they found a loose connection somewhere in the wiring.
  3. GlmnAlyAirCar
    GlmnAlyAirCar Active Member
    Southeast PA
    Wow, that sounds pretty bad. I would make sure you leave it with them unt they have absolutely identified and fixed the problem. Hopefully they have a loaner for you.
  4. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
  5. brkaus
    brkaus Well-Known Member
    Austin, TX
    Make lemonade?
    Document everything...
  6. flashflood
    flashflood Member
    Los Altos Hills, CA
    That makes no sense. A memory leak is a software bug, which is always fixable. And lots of other cars are running the same software without having these issues, so it's probably not a software bug in the first place.
  7. brkaus
    Austin, TX
    flashflood is correct, a memory leak should cause problems for all cars running the same software. Or at least a portion of them that are using it the same as you. Not something that would disable a single car. It would also be solvable.
    More likely, this is something with your car. A failing component or a bad connection.
  8. flashflood
    flashflood Member
    Los Altos Hills, CA
    Exactly. Most likely there's some hardware component in distress, which is causing the software to repeatedly execute a normally rare error path, and that error path has a memory leak. Probably something as simple/stupid as a sprintf() buffer. But, again, this would be fixable.
  9. Zybd1201
    Zybd1201 Member
    Rest assured the first thing they tell you will almost always be completely incorrect. ;-)
    I am pretty sure there is even a mathematical proof of it...
    • Funny x 2
  10. MileHighMotoring
    Parker, CO
    This has been going on for a year. I document all the problems, and they tell me there's no fix. I basically demand they replace electrical components until it's fixed, and they don't. Corporate ignores me. Not sure who to call or email.
  11. AwesomeBallz
    AwesomeBallz New Member
    Boston
    Picked up brand new Model X yesterday and got exact error this morning. Service is currently running diagnostics.
  12. Zybd1201
    Zybd1201 Member
    They speak only one language...
    NHTSA and Lemon Law..
    Sad but not unique to Tesla at all. Just a fact of life when dealing with large manufacturers.
  13. MileHighMotoring
    Parker, CO
    I just want it fixed. I don't want to start a war. My car goes to the shop for this steering thing on Monday. I'll ask who I need to contact at corporate to get my gremlins dealt with. "Memory Leak with no cure" is not acceptable.
  14. vgrinshpun
    vgrinshpun Supporting Member
    PA
    I had a similar loss of power steering, that was initially "fixed" by restarting the car, but eventually deteriorated over the course of three days to multiple warnings related to various systems (ABS, ESC, and others). At that point the car was not drivable. It was diagnosed as a connection problem at one of the posts of the lead-acid battery, which resulted in loss of the ground. After cleaning the post and the terminal and re-connecting, the problem was fixed and never came back (this happened 1 year and 2 months ago).
    Given problems wit unrelated systems - steering and parking sensors - I think that the most likely culprit is poor ground or loose connections somewhere in the auxiliary power circuit.
    • Informative x 2
  15. davidsouther
    davidsouther New Member
    Pittsburgh, PA
    Same happened to me - S60, took delivery end of Q4 2016, had the issue three or four weeks later.
  16. xborg
    xborg Member
    London
    Don't ignore it, it is dangerous.
    Apparently, it is a common issue nowadays.
  17. Skotty
    Skotty 2014 Model S P85
    Kansas City, MO
    I just got this problem today. Reboot didn't clear it. Stopping and starting car again did clear it. For now, anyway.
    Things I should check? Does Tesla steering have any fluid to check? I would guess not, but not sure. From this thread, sounds like I should check the terminals to the battery to ensure they are firmly attached and clean.
  18. MileHighMotoring
    Parker, CO
    They had to replace my entire steering rack. Later they had to replace my steering wheel because it got all wonky (the heat would mysteriously turn on, the thumb wheels weren't reliable, the Auto Pilot wouldn't sense my hands on the wheel, etc)
  19. brkaus
    Austin, TX
    Oh no, another wonky wheel!
    (Sorry, couldn't resist)
  20. MileHighMotoring
    Parker, CO
