Steering Assist Reduced
Discussion in 'Model X: Driving Dynamics' started by gnguyen, May 24, 2017.
  1. gnguyen
    gnguyen Member
    Had this happen to me today. While driving to drop the kids off, occasionally the steering wheel would for a brief moment get very stiff, then go back to normal. AP2 AutoSteer never became available, despite being available on the same roads the previous day.
    When I got to school, driving over the curb and over the bump of the security gate rail apparently caused all power steering to just fail, and the wheel stayed stiff and the car flashed a "Car Needs Service - Steering Assist Reduced" sign on the dash and on the touchscreen. I was pointing straight at a handicapped spot so I just drove right into it and parked, dropped off the kids and went back to call Roadside Service.
    ETA was an hour for someone to come take the car. Before they called me back I was fiddling with various resets and leaving the car/coming back, pressing the brake, and the steering came back. I decided to take the car myself straight to the service center.
    When the steering assist is off, it's WAY more stiff than an old school manual steering car. You will need both hands to turn the wheel. Luckily it briefly triggered off only one more time before getting on the highway, and I got to the service center safely. There they wanted to test drive it, and the technician could feel the issue happen occasionally. He was able to trigger it again completely by going over a few speed bumps. AP2 AutoSteer never became available again either.
    The initial diagnosis is a loose wire somewhere that's causing the power steering to fail. A few people have had this issue with their Model S's as well, looking around the forums. The service center is going to take a pretty careful look, as its a serious safety issue.
    I'm pretty disappointed that this is a thing. If it's a loose wire, there's some shoddy assembly line work happening, or some pretty poor quality control. I'm just glad nothing scary happened, as it could have.
  2. Yinn
    Yinn Active Member
    Behind you
    Any idea which wire it is? A couple of us have had this happen, but with no error lights. It's been giving an impression of a "dead spot" in the steering for AP2's.
  3. MS16
    MS16 Member
    Calif
    Keep us posted, something as significant as a steering problem is an item you definitely hope they find a hard failure, and not just a repair based on the technician's speculation.
  4. gnguyen
    gnguyen Member
    They are going to be pretty thorough because it's a safety issue. I hope it's simple though and not something more difficult an issue to solve. It seemed like something they had encountered before.
  5. gnguyen
    gnguyen Member
    Posted this in the Model S thread on the same subject:
    I got the car back today from service. They said they found the loose power steering ground connection. Reattached, they took it out for a test drive over some bumps, checked again and it didn't move. So they called it fixed.
    It seems fine right now. AutoPilot fully functional and no steering wheel lockups. Let's hope it's fixed for sure.
    The tech said that it is a pretty rare issue, which is good news for everyone else.
  6. Yinn
    Yinn Active Member
    Behind you
    Funny, in the S thread I stated that it felt like a failing power steering pump...now I have to find where that ground is to make sure mine is tight.
  7. MS16
    MS16 Member
    Calif
    Did you have the Service Center look at it?
  8. Yinn
    Yinn Active Member
    Behind you
    Yup.
    Good: They found a malfunctioning wheel speed sensor - which surprisingly didn't trigger any warning lights.
    Bad: It didn't solve the problem.
  9. MS16
    MS16 Member
    Calif
    Are they still trying to find the problem?
  10. cantbechanged
    cantbechanged Member
    Hawaii
    We just had this error too.
    Car needs service: Steering Assist Reduced.
    Park assist unavailable.
    The FWDs also did not open, even with override.
    I tried resetting both computers, with and without the brake. The car has an update scheduled for tonight, so when I got home just now, I set it to update immediately.
  11. soaring47
    soaring47 Member
    Had this error appear In my first week of ownership, about 170 miles in. Called Roadside assistance and resolved the error by:
    - rebooting (hold down brake and both steering scroll wheels until it resets)
    - turning the car off and waiting 3 minutes before putting foot on brake again.
    Haven’t had the issue since
  12. redy
    redy Member
    Brooklyn
    Happened to me just now. Resolved with the above steps. Thanks for that.
    Question is what's the significance of it? Did it happen to you guys again after it resolved? Do I need to take it to servicing?
    Problem is I have a big family trip to Ohio coming up next Thursday. Can't take chances but at the same time can't have it sitting in the service center....
    Edit: just realized this was in the model x forum. Mine is a model S.
