Steering "Click" at stop and low speed--normal or not
Discussion in 'Model S: User Interface' started by efusco, Apr 5, 2013.
  1. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    #1 efusco, Apr 5, 2013
    Over the past week I began to notice that when I would turn my steering wheel more than about 180 degrees in either direction I would hear and feel (slighly) a click that seems to come from under the dash/frunk area. I can get up to 3 clicks at varying intervals in each direction the last occurring just before hitting the stop. The clicking is noticable when driving at very low speed (below ~10mph) when making hard turns (eg turning into a parking spot), but is not present at all with normal driving speeds.
    Leo McAdams was here today to address some of my other minor issues and I asked him to look at it and he took an audio recording to send to engineering. He said he'd never noticed it before but hadn't looked for it and was going to check the next car he's looking at in Little Rock today to see if it does it or not. He didn't feel it was a safety issue since it doesn't occur when driving normally.
    Just wondering if anyone else has seen/heard this?
  2. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    That's a tough one to describe.
    I know on blacktop surfaces I get an occasional sound/feel ...but I know it's the tire slipping on the blacktop in a mid to tight turn...
    Don't know if that sounds familiar....
  3. efusco
    No, this is clearly mechanical clicking of internal components of the steering system. Uploading a video now, but I can't promise how good the sound quality will be.
    - - - Updated - - -
    Video added to the first post.
  4. steve841
    Ft. Lauderdale, FL
    Whoa..... Way off from what I first thought...
  5. MikeC
    MikeC Supporting Member
    Los Angeles
    That's loud! I just checked and do not have the clicking on mine.
  6. efusco
    Yea, it's very noticable...the service guy gave a "Whoa!" when he heard it too.
    Thanks for confirming that it's not on yours Mike...I think it just started a week or so ago, but it's one of those things that's not so bad as to be confident that it couldn't have been there before.
  7. FalconNinetyD
    FalconNinetyD Active Member
    My car developed that about a month ago, after 2 months of not having it. I mentioned it in the Technical/Mechanical issues thread on March 5th.
    I reported it to my local service center, but they failed to address it when they had my car overnight earlier in the week :mad:
  8. Quibbs
    Quibbs Member
    Southeast US
    #8 Quibbs, Apr 6, 2013
    My 2012 Porsche 911 makes noise worse than that when I turn the wheels all the way to the left or right. It's a known issue and it feels mechanical, but Porsche says it's "normal". Some Pcar owners say it's the tires, others say it's the electric power steering. That developed on mine after the first 2000 miles.
    Currently my MS does not have the click yours does, but now I'm worried. How many miles do you on your MS?
  9. efusco
    Started somewhere around 5000 miles, at 6000 now.
  10. Born 2 Skydive
    Boone, North Carolina
    My P85 started doing it too. I only hear it during parking maneuvers. Javier from Tesla Raleigh NC came and took care of it. He removed the bin from the frunk and we could hear where the sound originated from. He loosen a couple of bolts and lubed it and the clicking disappeared
  11. efusco
    No idea what it was, exactly? Glad to know it was an easy fix, but it seems odd, it sounds like something catching on something and it's unusual that it's only at low speed or when stopped that it occurs...
    Thank you for letting me know that though.
  12. brianman
    brianman Burrito Founder
    Just an FYI...
    I heard what sounded like the same clicking (from outside the vehicle) when someone was moving a vehicle around at the event at Metropolitan Detail today. I meant to mention it to the owner but got distracted. :(
  13. Twiddler
    Twiddler Member
    DFW
    Could it be the CV joints? Would be awfully early for those to be the problem, having wore down many myself :cursing:
  14. strider
    strider Active Member
    NE Oklahoma
    MS is rear-wheel drive only. No CV's.
  15. alset
    alset Member
    Boston
    I'm getting this now too, was just occasionally, now becoming more regular. Happens near full lock so naturally only at low speed maneuvering.
    Going in for service today so I will see what they can do.
  16. efusco
    Ok...let me add another twist...
    About the same time I started noticing the steering wheel click phenomenon, I started noticing that every once in a while, usually after a period of 6-12 hours left undriven and usually after being charged, that when I stepped on the brake it seemed FAR more firm that usual and would take a bit to gradually depress to the normal "full depressed" position. Once it was down the brake pedal feedback pressure is the same as it always was.
    Any connection?
  17. Plug Me In
    Plug Me In Member
    Central Virginia
    I just noticed the click as well the past couple of days, while maneuvering in a friend's driveway. It's more low speed/no speed extreme steering wheel turning than I normally do. Haven't noticed anything else out of the ordinary other than I got the TPMS service warning for the first time today. I'm still waiting on 4.3, so hope that will make that warning go away.
  18. alset
    alset Member
    Boston
    Service adjusted torque on some nuts somewhere (steering rack?) and it's all good. Seems like nothing to worry about and just take care of it when convenient.
    BTW, the first time anyone gets a TPMS warning, I would check tire pressures. It would be unusual to have a low tire pressure warning though with temperatures increasing (+1 psi for every 10 degrees F). Could also be a slow leak, it can actually work as intended sometimes. :)
  19. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    No, that's normal. Something to do with the brake fluids pressurizing.
  20. efusco
    Yea, I'll have to get Leo to look at that too, certainly once I'm rolling it's not an issue, but feels odd that the pedal doesn't depress normally when stepping on it.
