Steering clicks
Discussion in 'Model S: Driving Dynamics' started by steilkurve, Jul 31, 2015.
  1. steilkurve
    steilkurve Member
    Montreal, Canada
    #1 steilkurve, Jul 31, 2015
    Been noticing clicks from steering rack of my 4-month old P85D when turning wheel full left or right at stop or very, very low speed. Usually happens when I get out of my garage or a tight parking spot and need to make a hard turn right away. Searched the forums and saw this was an issue mostly in 2013 and a bit in 2014 but I can't find anything on it of late. Anyone experienced it on recent cars? Is the fix still shims and bolt torque? Does Tesla not address at the factory if known? Thanks.
  2. Lump
    Lump Active Member
    So. Cal.
    Family member took delivery of standard 85 in January & had what you described, service center first said it was normal but after a second visit increasing torque resolved issue, they are now waiting for a drive unit replacement.
  3. beeeerock
    beeeerock Active Member
    Kamloops BC Canada
    I've got a May 2015 with what sounds like the same sound. My service guy knew exactly what it was and confirms the solution noted above of increasing the torque somewhere in the system. I don't think it's a safety issue (at least I didn't get that inference) so won't be dealing with it until I've got reason to be in Vancouver.
  4. Denarius
    Denarius Active Member
    Utah
    I've noticed this in my P85D. Maybe it is time to reach out to service.
  5. doctorwho
    doctorwho Active Member
    Eurobin, Victoria. Australia
    I have the same in my 85, usually around full lock, usually when the car is cold, definitely coming from the front suspension/steering (I've heard it from outside the car). It only happens occasionally though
  6. hpham007
    hpham007 Banned
    Houston
    Did they take delivery Jan of THIS year? Are drive unit issues still showing up in newer builds? I thought this issue was resolved.
  7. ToddRLockwood
    ToddRLockwood Active Member
    Burlington, Vermont
    Surprising. I thought Tesla had solved this one some time ago. The clicking occurs at the steering rack mounting points, where the rack bolts to the car's frame. The clicks come from very slight movement as the rack ears rub against the chassis mounts while under high stress, such as when steering while the car is stationery. This is NOT a dangerous condition. The problem is remedied with a shim and a special type of grease.
  8. steilkurve
    steilkurve Member
    Montreal, Canada
    What is the drive unit issue? It's not related to clicks I described above is it?
  9. Lump
    Lump Active Member
    So. Cal.
    Yes, Jan 2015 delivery & started hearing "milling" sound from the DU.
    - - - Updated - - -
    Separate issue from steering.
  10. steilkurve
    steilkurve Member
    Montreal, Canada
    Ok. Thanks. I shall contact my SC for the fix.
  11. Firewired
    Firewired Member
    San Antonio
    I have the same on a December delivery P85D.
  12. steilkurve
    steilkurve Member
    Montreal, Canada
    Did you get it fixed? Solved it, if so?
  13. Firewired
    Firewired Member
    San Antonio
    No. I also had a bad gasket on the steering column which was making more noise then the clicks. Every time I would turn the steering wheel at low speed it would make a low moan. They initially tried greasing it up, but found that the gasket was cinching up on the steering column still with turns, and finally replaced it. So now that that noise is (thankfully) gone I can hear that same clicking noise described definitely from the front end when doing low speed maneuvers. I am on a road trip from San Antonio to Chicago right now, but will try and get the clicking addressed when I get back.
  14. Racerx22b
    Racerx22b @unplggdd on Instagram
    West Palm Beach, FL
    Had the same issue on my 85 (delivered Mid Feb 2015). Service torqued something in the steering assembly (sorry don't have more specifics) and it was fixed. This was done a few weeks ago.
    Jason
  15. mibaro2
    mibaro2 Member
    Georgetown, ON
    When I had the same problem last summer, the SC fixed it when I brought my car in to put winter tires on. I wasn't sure if the noise was normal or not either. They fixed it without me asking them to (guess they heard the click when driving it). It was in the steering rack mount points.
  16. agloutney
    agloutney Member
    Montreal
    I had the same issue. December 2014 S85. Service changed the bolts to shorter ones and the issue has not reoccurred.
  17. Fezzik
    Fezzik P100D, M3LR
    Lincolnshire, IL
    My p85d had clicking. There was a service bulletin about it. Took it in and was fix and no probs since feb
  18. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    Seems crazy that these newer cars are coming from the factory with problems that have been resolved for quite some time. I don't think mine ever did this at least not that I can recall, and I have an older 2013 P85. I guess they proactively fixed mine one of the times it was in for service or before I took delivery. Point is, they shouldn't be coming off the floor like this new with a known solution, should they?
  19. Khatsalano
    Khatsalano Member
    San Mateo, CA
    Had the same issue. February 2015 S85D with air.
    I brought it into the service center and the shim bulletin was applied. It solved about 90% of the cases, but it still can be audible at times. I can live with it since it only happens at extreme ends of travel and in low-speed situations.
    - K
  20. dlt
    dlt Member
    Finland
    Same here, P85D 68874, manufactured Jan'15. The issue appeared after 6-8000 km, and has become worse since.
    The car is going to Helsinki SC (for 20.000 km check) this week and they should fix this too, in addition to a couple of minor issues.
