Stereo Sound System Uprade
I'm wanting to upgrade my sound system in my 1.5. If I have a new Alpine touchscreen stereo, a pair of tweeters, a pair of mid-range, a pair of 5.25 sub-woofers, and an amp installed...will this effect or pull too much power from the battery? Will it effect my current range mileage? Of course, the installation shop says it won't be an issue...but they are not Roadster Specialists like we have on this forum.
What do you guys think?
Thanks
Mike
JohnGarziglia
#1243
203
122
Reston, Virginia
What I did with my 2.5 prior to replacing the double-din Alpine receiver with its auxiliary HD radio components was to connect up the replacement system on a bench to a 12 volt power supply (or a 12 volt battery works fine), and measure the amperage at full blast. Then I measured the amperage used by the installed system through the fuse block. I found that the replacement system pulled a little less current than the existing system. Unless you are putting in something designed to shake the asphalt under the car, I doubt any replacement system will pull more substantially more current than the existing system does.
My aftermarket amp had an extra 12V battery installed.
This was done by the previous owner but I gather that the system was installed by http://al-ed.com/ who apparently did this on a couple of Roadsters.
If you ask me, I would NOT do that though.
This is not a car that benefits from a better sound system. Put in a better radio, but I would otherwise forego the better amp et al. The standard system is pretty decent. The radio is just *sugar*.
It looks like the factory fuse ratings for the head unit is 7.5A and 15A for the subwoofer amp. So, if you can keep the consumption below 90W and 180W RMS respectively then you should be ok using into the original fuse locations.
If you keep within these limits it really shouldn't consume a lot of extra energy. If I were to guesstimate, I would put the power consumption (at moderate volume levels)) on par with running the headlights at night.
If you are looking for more power, consider installing speakers that operate at a sensitivity at or above 90dB/2.83V. With more efficient speakers the system will be considerably louder as compared to speakers that operate at 85dB/2.83V.
agree partly.
I upgraded my unit recently and can definitely hear the difference. Alpine 702d.
But even better: the apple/Android CarPlay experience.
X.l.r.8
1,611
1,070
Toronto/Tampa
JL tr400-cxi. 84. 1 7/8. 2-35 71-22,000
R1525x2. 88 1 7/8. 2-40 62-20,000
R14x2. 85. 1 11/16 2-30 100-20,000
Gto429 92 1 15/16 5-35 75-21,000
Ref-4002cfx 92. 1 7/8. 5-35. 75-21,000
Ref-4012i. 91. 1 15/16 2-35. 85-21,000
Kar110 90. 54mm 5-100 30-20,000
Ki 46csc44 88. 1 1/4 5-50. 60-20,000
Ki 44ksc404 88. 1 13/16 0-75. 60-20,000
Polk DB 402 90 1 13/16 5-45. 60-22,000
In ref4032cfx.92 1 7/8. 5-35. 75-21,000
figures are DB, mounting depth, power range, and grew-range. Just in case anyone is looking, this was a quick list of speakers I was playing with before I found my uniQ’s
