Still missing most recent update
Discussion in 'Model S' started by DMan, Jan 22, 2019.
  1. DMan
    DMan Member
    WA
    I tried rebooting the big screen a couple of times to try to "push" the update but that didn't work. Any other ideas to get the most recent update rather than going to a service center?
  2. ucmndd
    ucmndd Well-Known Member
    Call the 800 number number and start there. They can often remotely diagnose an issue and re-push.
  3. jorobsand
    jorobsand Member
    Charlotte, NC
    What version are you currently on? Tesla typically has multiple firmware versions that are considered "current" at the same time. Most should be on at least 2018.48.12.1.
    I agree that calling the 800 number is usually quicker. They can typically tell pretty quickly if you have a failed update that is holding you up or if you are "current".
  4. csanders90D
    csanders90D Supporting Member
    San Diego, CA
    Unless you've gone 3 months or more (which would be around version 2019.42) there's no reason to worry about it. Not everyone gets every version, and it's common to be a month or more between updates.
  5. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    Are you connected to WiFi. If not, make sure that you are.
    It will come.(but much, much slower over cellular)
  6. DMan
    DMan Member
    WA
    I'm on 2018.42.3 eb373a0 right now
  7. ucmndd
    Normally I agree with this but the 2018.49 Christmas Easter egg was supposed to be pushed to basically every car. If OP doesn’t have that yet, which it appears he doesn’t based on the last post, something needs to be addressed.
    OP, call the 800 number. That’s your fix.
  8. DMan
    DMan Member
    WA
    Thanks for all the responses. I was able to get through to someone using Tesla chat. They told me that the size of the update was so big that I needed to connect it to WiFi. The WiFi is weak where I keep my car parked so need to figure out a stronger spot to park it while it updates. Hopefully this helps anyone having the same issue!
  9. DrTharp
    DrTharp Member
    Waco, Texas
    What is the 800 number please. I have the same issue.
  10. ucmndd
  11. Pinot.Noir
    Pinot.Noir Member
    Livermore, CA
    Don't feel bad, I'm still on 2018.39.6
  12. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    FYI there’s only one 800 number and it’s always available in the car. Recommend adding it to your phone contact list for use when not in the car.
