Storage Mode for Four Weeks?
Discussion in 'Roadster 2008-2012' started by smicker, May 12, 2013.
Tags:
  1. smicker
    smicker Roadster 1020
    Berlin, Germany
    Hi All--
    Ill be going away for four weeks--is this long enough to warrant leaving plugged in in storage mode or okay to just charge up in standard mode and unplug? If storage mode, I have two charging options--110/12A and 220/20A--is one better than the other?
    --Paul
  2. djp
    djp Model 3 Performance
    Toronto, Canada
    I wouldn't leave it unplugged. If you get a stretch of hot weather the BMS might run down the battery trying to keep it cool.
    I'd leave it in Storage Mode plugged into a 240V outlet.
  3. NEWDL
    NEWDL R#350 R#1323 Sig23(traded) 8136, RWD LR 3, P3D
    NE OHIO
    ^^ What he said ^^
    I agree
  4. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    Plug it in. Either 110 or 220, whatever is most convenient. I'd probably do Storage Mode, but Standard Mode would also be fine. If you do Storage Mode, be sure to select Standard Mode the day before you drive it, so it can fully charge overnight (at 220 if possible).
