Storm Watch - what triggers it?
North Texas is currently under a winter storm warning lasting through Monday. I have storm watch enabled but it is not “active”.
I’m a bit worried because it has been so cloudy all week, I’ve just remained at my reserve of 40%. I switched to backup only to charge as much as I can, but getting very little with the cloud cover.
who or what determines an active storm watch mode? I thought it was based on NWS?
Tesla triggers it, based on NWS warnings.
EDIT: I should say that, in my experience, stormwatch are triggered when your area is in the highest form of whatever NWS information is showing.
For example, if your specific area is under a winter storm advisory, or winter storm watch, it is unlikely stormwatch would be triggered. If your are is under a winter storm warning then stormwatch likely would be triggered, if the warning was for your specific zip code.
Its only on the highest (warning) that it seems to trigger, and not always then, if your specific area is not predicted to be impacted. At least that has been my experience (and more around high winds, not winter storms, but should be the same)
Well reading the warning it would seem this is about as high as it gets...
“..HISTORIC WINTER STORM POISED TO IMPACT THE REGION SUNDAY...”
Is storm watch supposed to be automated? Or am I depending on someone at Tesla to keep up with the weather conditions across the country and “allow” me to grid charge on a case by case basis? seems a little vague.
maybe it will kick on sometime Saturday or Sunday... grid in my area is pretty stable, but still would like to know the feature works when it should...
I would imagine "north texas" is a fairly large area? It appears to me that they (tesla) narrow it down to zip codes, not large geographic areas. There isnt anything you need to (or can) do to "make it work" other than turn it on so that if they trigger it in the app, it will charge.
As for the actual triggering mechanism, I only know that tesla is responsible for it, and they use NWS data for it. As to whether someone has to approve it for an area or not, or its automated by zip code or something, I dont know.
If the storm is in "your area" but isnt projected to hit your zip code directly (for example) they likely wont turn it on. My city is about 26 square miles, and there are 3 zip codes here. I think stormwatch has been on for people in one of the zip codes in my city and not the other 2, for example.
They try to narrow the range, not widen it, at least thats what it seems like to me.
Storm Watch was triggered in the Houston area in advance of the cold weather and in time for the PowerWalls to get to 100% charge before the cold weather hit.
So that worked as it should.
But... Overnight when the grid appears to have gotten back to normal, Storm Watch was deactivated, so our PowerWalls started discharging.
Since I don't trust that the grid is really fixed after only a few hours of "normal" operation, I manually set our system to Self-Powered with a 95% reserve - and will keep it that way until we've gone at least 24 hours without any grid issues.
It would be very useful if Tesla would add notifications about "Storm Watch activated" and "Storm Watch deactivate".
We also never got app notifications on the grid going offline.
The only notification I received was an e-mail after the grid went offline, with suggestions of how to manage the PowerWalls during grid outages.
