Stranded! (forgot keyfob at home, was still able to drive car away)
Discussion in 'Model S: User Interface' started by carrerascott, May 15, 2013.
  1. carrerascott
    carrerascott FUEL FTR
    Charlottesville, Virginia
    Argh. Wife put the key on a shelf near the car. We were in a hurry and hopped in and drove off to my son's school. Parked. Realized we didn't have the key. No warnings until trying to turn it on now. Big flaw!
    Luckily neighbor is bringing the key. What if we had driven 200 miles before stopping?
    This needs to be addressed!
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Does need to be addressed but have you attached your Model S keyfob to your house keys? That makes this much less likely.
  3. YoungStranger
    YoungStranger Member
    Telford UK
    there would be a straightforward fix for this - a warning on screen as soon as the key goes out of range... The car could stop, but that would be dangerous
  4. carrerascott
    #4 carrerascott, May 15, 2013
    Needs a real audio and visual warning!
  5. dsm363
    Nevada
    It does need to do this and it should be more obvious. Attaching the keyfob to your house key (assuming you use a physical key to lock your house when you leave) would virtually eliminate this problem until they offer a better fix.
  6. mitch672
    mitch672 Active Member
    Stoughton, MA
    #6 mitch672, May 15, 2013
    They could also have some kinda of override using the smartphone app, that would solve the keyfob being left nearby issue.
    Perhaps a secondary password to enable it, for extra security.
    Even if you do not have your smartphone you could call the significant other and get them to do the override, or Tesla service could also via a phone call (again a secondary security password would be required).
    Elon, if your reading this, your welcome :)
  7. gregincal
    gregincal Active Member
    Santa Cruz, CA
    I can't imagine people really wanting to do this, so a big flashing warning with a tone does seem appropriate.
  8. bollar
    bollar Disgruntled Member
    Southlake, TX
    Interesting. I had assumed the car was using Keyless Go, but KG has sensors that confirm the key is physically inside the car before it will allow a start.
  9. jerry33
    Texas
    The correct way to fix this problem is to insure that the car won't start unless the fob is actually inside the car. That is how other manufacturers do it. Of course, you can still get stuck like the OP if you toss the keys out the window or if you exit with the car running and leave the fob somewhere, but it's much less likely.
  10. dsm363
    Nevada
    It sounds like the keyfob was placed on a shelf in the garage close enough to the car to make the Model S think it was inside allowing it to start.
  11. ZBB
    ZBB Emperor
    Scottsdale
    I had an '08 CTS that had the keyless option. The car would give an attention gong and display a message on the dash if the key was not in the car and in gear. But it also would not start if the key was not inside the car (so that message would not come up unless the car was on and you got out of the car with the key and then got back in to drive and didn't bring the key back (say changing drivers...).
    Why doesn't Tesla do that?
  12. cinergi
    cinergi Active Member
    MA
    If you haven't already, please let ownership know about your experience and desire for an improvement (e.g. where the car alerts you while driving).
  13. Johan
    Johan Ex got M3 in the divorce, waiting for EU Model Y!
    Drammen, Norway
    My Volvo V70 (2011) warns me with blinking lights and loud bells if the fob is removed from the car while the engine is on (or of the car is removed from the fob, as in the OP). For it to do this I guess it somehow keeps "pinging" the fob? Would this drain the battery of the fob quicker? However, my batteries last for years...
  14. bollar
    Southlake, TX
    Yeah, but my KG system rarely makes that mistake. I can have the key in my open palm just outside the driver's window and the car will give a "key not recognized" warning. Move it inside a couple of inches and the car starts.
    If it is a KG system, there's tuning to be done.
  15. carrerascott
    We don't use house keys so that won't solve it.
  16. carrerascott
    Correct. And got no warning that I noticed. Didn't realize till we were parked and looking for the keys.
  17. carrerascott
    I will when I get home, for sure.
  18. dsm363
    Nevada
    I know that warning is small and not that obvious but you didn't get that 'key not inside' warning when you drove away? I've had a few times where the key fob was in the car and it thought it wasn't and that message popped up but that was with earlier software versions.
  19. kinddog
    kinddog Banned
    Northern Virginia
    on a side note, I have lost one of my key fobs.
    anyone know how much a replacement costs?
  20. NigelM
    NigelM Recovering Member
    Northern Virginia
    #20 NigelM, May 15, 2013
    That warning is there. I've had it when the key was in my pocket shielded by my phone. It goes away after howevermanyseconds though.
    - - - Updated - - -
    It's $230 posted here. Note that you still need a Service Tech to reset BOTH keys at once when you get a new one.
