Concern: Customer: Vehicle will not shift into gear. Drive unit must be replaced.
Corrections: Instrument Panel General Diagnosis
Rear large drive unit needs, halfshaft assemblies and hubs need to be replaced.
Corrections: Drive Unit - Rear - Large
Replace rear Drive Unit and performed test drive. Vehicle operating as designed.
Part Quantity
ASY,PTRAIN,
RMN,MDLS,BASE,CMC,HS,FA2+
(1025276-00-Q)
G-48 COOLANT (1029320-00-A) 1
212-B ATF (1031106-00-A) 3
Parts Replaced or Added
Corrections: Upgrade the Side Motor Mount
While installing the new rear drive unit, the side motor mount was upgraded.
Part Quantity
SIDE MOTOR MOUNT ASSEMBLY (1028034
-00-B)
Corrections: Halfshaft Assembly - Rear - LH
Removed and replaced left rear halfshaft assembly.
Part Quantity
REAR HALFSHAFT 36 MM, PERFORMANCE
(1007719-01-B)
WASHER SAFETY M24x39 (1020296-00-B) 1
NUT HF M24x1.5 [8.8] ZnFl-W (1020297-00-
A)
Corrections: Halfshaft Assembly - Rear - RH
Removed and replaced right rear halfshaft assembly.
Part Quantity
(1007719-01-B)
A)
Corrections: Hub - Rear - LH
Removed and replaced left rear hub. Vehicle operating as designed.
Part Quantity
RR SUSP HUB AND BEARING ASSY
PERFORMANCE (1027170-00-A)
Corrections: Hub - Rear - RH
Removed and replaced right rear hub. Vehicle operating as designed.
Part Quantity
