Strange. Anyone else having climate turning on, not by you?
No ICE
2016 S75D pearl AP1, & 2014 silver S85 AP1
Apr 10, 2016
102
72
Kansas City
I feel like I am going crazy, lately over the last week only (post new soft ware update) my cars climate control has turned itself heat on while it’s in the garage charging? Not at work while it is not plugged in? Weird I am not turning it on remotely. When It happens It’s always set at 82 degrees which I never set the temp to? Anybody having this happen?
Kinda pissing me off, I have no idea how long it’s been heating at 82. And running off my electricity at home to heat an empty car up! I just caught it running on my app again and it’s 8pm, it would been on all night I assume?
Just curious if anybody is seeing this happen?
Reactions: IdaX
aptekcom
32
11
Houston
YES! I was thinking i'm going crazy. i went to the garage at 600am this morning and heard this loud fan sound. Turned out it was the car. I turned the climate off and it went off. Then, this evening, same thing, but this time the climate was off! This just started over the last couple of days. Any ideas?
Reactions: IdaX
tktktk
48
49
Milwaukee
Yes....all the time over past 4 days. Never had the problem in past month of ownership. I store the key in the same location at home since I got the car a month ago and it occurs when at work with the key hundreds of feet from car so it's not key location /proximity to car nor is it smart enough to lesrn my schedule based on when climate system tuens on. Must be latest FW update....
Finally turned off preconditioning today as battery is getting killed with running continuously...at night, mid-day.....no rhyme or reason.
Have seen multiple page threads on here last summer but could not pinpoint root cause.
MonseyGuy
147
62
Monsey, NY
YES! Me too!
I though they just fixed the Cabin Preconditioning in the last update, which BTW NEVER worked as advertised since I got the car last March (2017 Tesla Model S). But who knows?
Today I woke up to the car being at 99 degrees since I have left it on HIGH the day before (Northeast winter...).
I don't know if this is a new "problem" or "bug" or pre-conditioning working again. Either way, it should certainly not default to HIGH if one left it on high.
Reactions: IdaX
Dec 9, 2012
17
0
Landenberg, PA
I was out of town for a day, left the car at 190 mi range and came back to 50 mi... shocking! Climate control getting turned on again and again, now I'm checking every half hour and turning it off... whackamole! this is just crazy
mknox
10,103
1,866
Toronto, ON
I just came back to one of my rear windows rolled down and 10 less miles, weird.
This drove me nuts for the first few months of ownership. Turns out it was (is) my left knee hitting the window switches which seem to be angled to align perfectly with my knee if I shift in the seat.
Do you have "Smart Preconditioning" turned on?
Raven
295
19
US
It’s your Smart Preconditioning. Turn it off in settings. I believe this feature only operates when plugged in. It’s remembering your habits and adjusting the climate to your setting when you normal use the car.
AndrewTX
192
156
Houston, Texas
My car started doing this when I installed 2018.4.5. Never happened before so I assume this is the root cause.
I don’t see Smart Preconditioning anywhere in settings. Can you point me to it? Thanks.
Reactions: IdaX
RV33
34
36
This started happening to me after the newest software update. I have always had Smart Preconditioning turned on, which never really worked at all, in my experience, until this past week. Mon-Fri I typically leave home at 9am, and on Sat-Sun, I have no consistent driving schedule.
But it seems to be turning on around 9am everyday, including weekend days. Plus I've seen the app running the climate for multiple hours past 9am. I found it running today at 1pm, and can only assume it started at 9am.
Running on the weekend doesn't seem to be a recent issue though. Found this comment from back in Oct '16.
It learns from your schedule. If your schedule is reasonably regular, it works pretty well. It did take quite a while before it zeroed in and stopped pre-conditioning at seemingly random times. It also pre-conditions on weekends for no reason. It seems like it would be pretty easy to program it so that it doesn't run on weekends if you don't have a regular schedule on weekends.
Ohji
96
159
Oregon
This was happening to me as well! I assumed I was somehow inadvertently hitting the widget on my phone when I was swiping between screens, but I've had the car for over a year and never accidentally enabled climate control before, so I doubt that was it. I have never had smart preconditioning on, and after this happened twice in January, I went to the car and confirmed smart conditioning was off. I enabled and immediately disabled preconditioning (just to toggle it to be sure), and then I rebooted the screen/MCU just in case something funny happened with the last software update. Knock on wood, I haven't had a random episode of the climate control coming back on again in the last couple of weeks...
Reactions: jschwefel
animorph
2,130
1,521
Scottsdale, AZ
Sometimes settings get changed during an update (though I've never had it happen personally). Sometimes it takes a reset or two after an update before it starts working properly.
Or maybe it's a bug and you are the guinea pig. None of the 2018 FW updates have been widely released yet.
rpm001
262
318
Toronto
I came on here to search for this thread because I think this is happening to me too. I just left my car at the airport unplugged with 78% and will be out of town for four days. I’m worried it will be dead when I get back. I do have smart preconditioning on, but never has it behaved this way until this last update. I’ll go into the garage to get something and hear the fan running. Look on the app and the climate is on.
Pretty sure this is new since the 2018.4 update. I’m not going to be happy if I get back and my car is dead. There is a ChargePoint about 5 min drive at the next terminal so hopefully it doesn’t go to zero.
Chad Meyer
7
14
New Jersey
It seems like Smart Preconditioning perhaps didn't work before, and with either the 2018.2 or 2018.4 update, it does. I too recently started seeing climate turn on by itself and it never did that.
micjh18
29
13
Indianapolis
Also happened to me after the latest update....only in my garage, with it unplugged or plugged in....weird. I turned off pre-conditioning and it hasn't happened since that.
Reactions: No ICE
Ruffles
309
379
Snohomish WA
Lol. I had the same thing. I noticed it on my phone mid trip however and turned off cabin heating mid trip so I limited the drain to ONLY 75 miles :)
masamitsu
77
36
Parker, Co
I just updated to 2018.4 last week and this happened to me this weekend. My wife came in from the garage and said my car was making a lot of noise. I went out there and couldn't figure out what was going on. Got in the car and was like man it's warm in here (FYI ; it was snowing on Saturday). Turned it off in the app.
kmistry1986
130
30
Cleveland, OH
Same happened to me the last week for a couple days. I turned off preconditioning and hasn't happened since so I assume something changed in the newest software update relating to that.
