Hi,
My roadster is sitting in the garage for about 6 weeks. I regularly check SOC, just to be sure everything is ok. Yesterday I had this readings:
V&T: Vmin: 3.79, Vmax:3.81
SOC: MIN/LIM: 47%, MAX: 55%
That seems odd. While voltage show a perfectly balanced battery, SOC shows the opposite. Isn't SOC calculated based on voltage? Why that can happen? And which of both is correct now? 8% difference in SOC seems very high, because AFAIK balancing starts only if lowest brick is 82% or higher, so I would need to charge in range mode to start balancing, right?
thanks, pascal
thanks, pascal
