Thanks Needs. How long does it last? I last checked a half hour ago, and will check now.Yes, my car does this when not asleep. Not sure if cooling fan or coolant pump or what. Has always done this from day one.
Sounds like the BMS (Battery Management System) cooling fan.This just started yesterday. Coming from the frunk area driver side. I rebooted the car and it’s still there. HVAC off, radio muted. Anyone else seen (heard) this. Next I’ll try shutting off the car. Strange.
Just checked. Car idling for an hour and 8 minutes, whirring noise still there. I’ll check again when it goes to sleep.
Runs until the car "goes to sleep". The problem is, however, that while at home, my car doesn't sleep that often as the WiFi keeps it awake. When at work it sleeps fine, but at home, not so much I've given up worrying about it because the vampire drain is pretty slight or the car is plugged in.
Ditto. They make lots of noises when parked - I don't worry about and get on with my life.Mine does this occasionally, but I've never timed how long the noise lasts....
Thanks very much Alan.It comes from here, as far as I can tell, and is present when the AC & fan are off. It's probably a pump circulating coolant.
Thanks Dead.Trying turning on Climate via the app, then turn climate off via the app after 5-15 secs.
I've had success doing this in the past when it did not seem the fan would stop on a mild temp day.
My car is almost always awake for 2 hours after every drive. Best I can tell, its how its designed and you can't do much about it.
that's a bit odd. Even in 40C my car takes I think around 20min.
Is it just the Wi-Fi connection that’s causing it to stay awake or something?
