Streaks on interior window
Discussion in 'Model X' started by ckwong, Jun 18, 2017.
Tags:
  1. ckwong
    ckwong Member
    Northern NJ
    Has anybody had this on both rear passenger window? After wiping it off and reopening the windows it comes back. It's only been 2 weeks...didn't get a chance to check this on D-day as I was too busy checking for other issues. Thanks!
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    I develop some streaks but they are much lighter than yours if I roll down the window when they are dirty. A car wash solves the problem until they become dirty again
  3. zackmilo
    zackmilo Matching X+3
    Los Angeles, CA
    Had the same thing. It got better over time. You can take it so SvC
  4. Pandamoanium
    Pandamoanium Member
    Colorado
    I've had this since last August. I've done the roll down and up and wipe countless times.
    I brought this to Tesla and they won't do anything because I got my windows tinted. They said it's left over from the stuff they put on for delivery or something along those lines.
  5. BeardedBro
    BeardedBro Member
    Palm Beach
    I have the same issue, and I don't agree with their explanation- my windows had those lines prior to them having been tinted. Additionally, the FWD windows do the same thing o_O
  6. ckwong
    ckwong Member
    Northern NJ
    This is happening to the FWD windows so they are factory tinted. I have an apt. with SC on tues for other issues so I will bring this up. Thanks guys!
  7. stillageek
    stillageek Member
    DFW
    Ours do this as well on the FWDs. I keep meaning to use Aquapel cleaner on them and the base.
  8. BeardedBro
    BeardedBro Member
    Palm Beach
    Please let us know if you have success with the aquapel- thanks
  9. Pandamoanium
    Pandamoanium Member
    Colorado
    I should clarify, it's the FWDs, fronts weren't as bad and I don't think they do it anymore.
  10. outie
    outie Active Member
    SoCal
    I thought we all have this issue.
  11. ckwong
    ckwong Member
    Northern NJ
    I'll report back after speaking with SC since my streaks are very noticeable.
  12. outie
    outie Active Member
    SoCal
    Do you open the window all the way up/down in 1 shot or at various heights?
    I only have 1 line which is from opening the window all the way down, then the streak would form immediately.
  13. ckwong
    ckwong Member
    Northern NJ
    The window was opened at various heights but I will clean it and try again to see if it makes any difference.
  14. dragonxt
    dragonxt Active Member
    Bay Area
    Noticed this too on my overnight drive.
    Looks like the only solution would be to wipe the windows down each time or not open them at all :(:mad:
  15. Pandamoanium
    Pandamoanium Member
    Colorado
    While not a big or even terrible issue, the small things really start to add up sometimes. Guess it's just helping us all bob up and down to look out, exercise!
  16. Seattle Tom
    Seattle Tom Member
    Seattle, WA
    I've got them, especially on the fwd windows. X received on June 1, so it's on my list when I take it into the service center. Mostly small issues like this which are annoying but not disastrous.
  17. joebob73
    joebob73 Member
    Los Angeles Area
    I had this issue on my X as well. When I took it to the service center, they mentioned that they see this a lot and it comes from some residue on the inside of the door in newly manufactured X's. They take the door apart and wipe off certain parts to remove the residue. Upon initial servicing, it was better, but not completely clear. Now that I've had the car for a couple of months after the service, it is completely clear. Hope that helps.
  18. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    I had a little bit on this on my X. Used some detailers clay (like I use on paint) and it was easily removed.
  19. ckwong
    ckwong Member
    Northern NJ
    After wiping it off it just comes back when ever I open the windows so like @joebob73 said I think there is probably some kind of residue inside the door...My MX is going in for service so I'll see what they say. Thanks though!
  20. earlyretirement
    earlyretirement Model X 90D
    San Diego, CA
    Yep. I've had this happen from Day 1 since I got it last August 2016. It's annoying. I will wash the windows well but if you roll down the windows the annoying lines come back. Doesn't seem to be any way to get rid of it.
