Stuck charge cord
Discussion in 'Model S: Battery & Charging' started by JRP3, Dec 6, 2012.
  1. JRP3
    JRP3 Hyperactive Member
    Central New York
  2. sublimaze1
    sublimaze1 8Dec2012 / Leeroy Jenkins
    Basin City, TX
    Only Jalopnik !!! :)
  3. RDoc
    RDoc S85D
    Boston North Shore
    Actually it was Autoweek. Jalopnik just reported it.
    I'd imagine Tesla is looking at exactly what happened very closely indeed.
  4. Zextraterrestrial
    Humboldt/Los Altos
    Is this Jalpnik's first article on Tesla since the last 'bad article'
  5. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    I have read on other forums of others having the same problem. I am having problems plugging in rather than plugging out, but with wiggling, it seems to work. I have been informed that there is a fix in the works, and I know Tesla will take care of any and all problems.
    Too bad the problem surfaced close enough for Jalopnik to be able to comment.
    I have had several other car makes in my lifetime (haven't most of you!) and the problem is when the company claims there is no problem and refuses to fix it. That has not happened with Tesla that I know of (other than perhaps Opportunity Consoles, and we really don't know if there is one coming thru Tesla, or if SoFlAuthor will be the main supplier).
  6. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    No; they had a very short blurb on the MT COTY award hidden away.
  7. Andrew Wolfe
    Andrew Wolfe Roadster 472 - S 440
    Los Gatos, CA
    lock & unlock the car and it fixes it.
  8. Zextraterrestrial
    Humboldt/Los Altos
    I cant pump gas in my wife's Lexus without holding the hose!
    I've had no problems with my plugs
    - - - Updated - - -
    they are pertty lame & foxy eh?
  9. JRP3
    Central New York
    I'd guess that didn't work in this case since the service tech had to take it apart.
  10. William13
    William13 Active Member
    South Bend
    I am sure that if I tried hard enough I could pull and torque on the plug while it was locked in place causing it to get stuck.
  11. Zythryn
    Zythryn Model Y custom Warming Stripes wrap.
    Minnesota
    The operator also tried to free the plug by sliding something in there. Don't know what order things happened, but if they were unfamiliar with the car I could see something like this:
    1) car is plugged in and locked
    2) reviewer goes to unplug cable with unlocking car
    3) cable won't release because car is locked
    4) not realizing this, he pulls harder, and even tries to jimmy the cable
    5) this damages the lock mechanism requiring a service call
    Now, that is pure speculation. I haven't seen any issues like this and the only time our charge cable was 'stuck' was because the door was locked:)
  12. tezco
    tezco Sig P85
    Colorado
    I charge with a J1772 and the adapter. I've noticed that when I disconnect the J1772, the locking mechanism holding the adapter in the charge port unlocks. Unless I pull out the adapter within a few seconds, the lock engages again and the adapter is stuck. Unlocking the doors doesn't release; I have to access the touchscreen to "open the charging port", which once again unlocks the adapter.
    The most worrisome thing is that simply disconnecting the J1772 causes the car to unlock the charging port (and adapter), even when you walk up to a locked car without the key fob. Be careful at public charging stations--I'm sure the J1772 adapter isn't cheap.
  13. Ceilidh
    Ceilidh Member
    Los Gatos/Santa Cruz Mountains/Silicon Valley, CA
    Having watched cinergy's (sp?) charging video, it would seem that having the j1772 turn off and then pulling out the plug without pushing the button that disconnects it from the adapter is the better way to go. Then you don't have to mess with removing the adapter by itself. You can just pull the plug off with the adapter still attached, then remove the adapter from the J1772 plug, which is easier, or so it would seem from the video.
    Don't have my car yet though, so this is all second hand. You can watch his video on youtube here:
    Tesla Model S J1772 Charging - YouTube
    Cheers
  14. Robert.Boston
    The sequence that my DS recommended is:
    1. From the center console Charging screen, touch the Stop Charging button.
    2. From the center console Controls screen, touch the Charge Port button in the unlock section.
    3. Pull the charging cable (still connected to the adapter) out of the car's charge port.
    4. Remove your adapter from the J1772 cable.
    5. Close the charge port door.
    6. Hang up the J1772 cable on the charger.
    7. Double-check that you've got your adapter!
  15. tezco
    tezco Sig P85
    Colorado
    My J1772 adapter is very hard to pull out of the charger port--takes two hands. If I pulled out using the plastic hook on my J1772, I'd probably break that hook off at some point. Main problem I'm worried about; however, is that the charge port unlocks for anyone on the street.
  16. JRP3
    Central New York
    I wonder if a thin coating of silicone grease might be helpful?
  17. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    Silicon grease might attract dirt. I was thinking to try what us sailors use to keep parts on our boats sliding: McLube Sailkote. It is a dry PTFE lubricant, which leaves only a microscopic dry and very slippery film.
  18. JRP3
    Central New York
    Yeah that sounds better. I'd cover any contacts when applying it.
  19. tezco
    tezco Sig P85
    Colorado
    Yes, I might spray some silicone spray on the end. I'll have to tape off the contacts and the other end that I grab hold of; otherwise it will be too slippery to pull out.
  20. cinergi
    cinergi Active Member
    MA
    There's a new version of the J1772 adapter that's not has hard to remove. Ask your service manager about it.
