Delivery on 10/10/18
Have only been driving the car a few days, and have only been using front driver/passenger doors. Yesterday I was giving the family test drives and noticed when I open the rear passenger door from the outside, the handle does not retract back into the door, it stays sprung open. When you shut the car door, it won't latch because the handle is stuck in the open position. If I lightly push on the handle it goes back into position. During delivery it did not act this way, so I didn't notice it.
I opened the door handle several times in case there was gunk in there that needed to be worked free but it still stays stuck open. It is almost as if the spring isn't strong enough to pull it back shut. I'm going to call service tomorrow to see what they recommend. I'd go at it with silicone spray but wanted to check with service first.
In the meantime, has anyone else experienced this issue, and are there any easy fix solutions?
