Hi all,
I am new to the forums but I have enjoyed reading everyone's experiences. Sorry but this will be a long post.
Background Info
Union City, CA (PG&E is provider)
Single Family House 1,855 sq ft (completely renovated 5 years ago when we bought the house)
Original House Built: 1972
Underground Power Lines: 100 amps only (nearest power distro box is across the street and down the block, about 130ft)
Current loads: All LED lights in the house, electric - AC / frig / washer / dishwasher / garbage disposal / Microwave / small radiant in floor heat in master bath (on timer) / gas - range / furnace / tankless water heater / dryer
Goals
2 Phase Project
Phase 1 - Add solar to cover current electric costs ($90 per month) and any additional infrastructure needed for Phase 2 and to future proof.
Phase 2 - Buy Model 3, add EV Charger, add powerwall/s and maybe more solar
I shopped around for the PV system and most likely going to go with Tesla Energy. We are currently going back and forth trying to figure out the design on the electrical side. They proposed a (12) 315w panel system (3.78kwh) with solaredge HD wave and power optimizers. This will cover more than what we are currently using.
CHALLENGES
Main Panel Upgrade
I want and am pretty sure a Main Panel Upgrade to 200 amps is needed. But PG&E says that I would be responsible for the trenching costs. I have quotes from $18 - $20k! On PG&Es EV webpage they make it seem as if they would consider "facility upgrade charges" as "common facilities" so the homeowner would not be responsible for those charges. However, they are only waiving the PG&E charges which doesn't include trenching. So that is a no go.
My current 100A main panel only has space for the 100A breaker that powers a sub panel that is in the garage where all of the house loads are, there is no space in the main panel to tie in the PV. PG&E doesn't allow line side taps.
PG&E will let us swap out the "a like for like" panel meaning a new 100A rated panel (they will not allow us to put in a 200A panel and derate it down to 100A with a breaker). However, Tesla is having a hard time finding a main panel that:
In this scenario we would NOT need a MPU but would be putting in a derated subpanel.
Can the new subpanel support more PV in the future, future 40A EV charger, and future powerwall? Would it and could it be rated for 200A and derated to 100A?
Does anyone know of a main panel that fits the requirements?
The PV ready panels I found have a breaker of 100A but a rating of 125A (so PG&E would not allow it), also Tesla said that those panels would not be compatible with a powerwall in the future. Not sure why.
I don't have a clear understanding of how a Powerwall and all of it other components (gateway, etc) tie into everything, but for Phase 1, I want to make sure that I put in the right equipment to support Phase 2.
Any insight / ideas / thoughts / recommendations / etc. would HELP!
Thanks
Background Info
Goals
2 Phase Project
CHALLENGES
Main Panel Upgrade
- rated for 100A
- branch breaker rating to meet panel rating (100A) (need this to still power my subpanel with the home loads)
- able to backfeed in the PV
- Space to support a future 40A EV Charger
- support for future powerwall
Thanks
