PG&E will have its own restrictions on how much solar you can connect to a 100A service. There are two issues:
1) They probably don't want you to be a net exporter over the course of the year (and it doesn't pay for you to be one, either). So they may limit your PV size based on your historical usage, or if you are getting an EV, based on an estimate of your future usage with EV.
2) If you put too much PV on your service, they will have to upgrade their equipment, and so they might either restrict the amount of PV, or want to charge you for the upgrades.
As a simple example, suppose your 100A service is on its own transformer, not shared with any other customers. A 100A service is nominally good for 24 kVA (24000 volt-amps), but it will not be served by a 25 kVA transformer, it would be, say, a 10 kVA transformer.
That is because NEC load calculations (used to size equipment you own) are very conservative, and prior to the advent of EVs and PV, there were basically no residential continuous loads. So even if your load calculation comes to 100A and you need a 100A service, actual monitoring of that service might show that your average current is only 10A, with very rare excursions above 40A. The 10 kVA transformer can handle intermittent overloading as long as it has time to cool down in between excursions above 40A (40A * 240V = 10 kVA, approximately)
But now if you put 60A of PV on your service, or if you get an EV and want to charge it at 60A, your demand profile has changed and you are actually trying to use your 100A service at 60A continuously for multiple hours. The 10 kVA transformer may no longer handle that, and PG&E would have to upgrade to a 15 kVA or 25 kVA transformer.
If your transformer is actually shared with other residences, then it is likely to have more reserve capacity, as long as you are the only customer on that transformer with an EV or PV.
Cheers, Wayne
