That is what I am trying to do, just need to know if anyone has run 8.5" rims on the front.
No worries with an 8.5" on front or rear. Guaranteed
Thanks Doc.
Your website also lists the Sottozero 3 as in the correct 19" size. Do you recommend to series 2 over the 3 for the 245/45 19 rims?
For Seattle winters where there is occasional ice but we are close to Canada would you recommend the performance winter tires? We don't see enough deep snow I think to make snow tires worth it.
I second this question. Doc, what do you recommend for us up in the Pacific Northwest where winter primarily means 30F - 50F and wet, very wet, with an occasional 3" - 6" of snow.
I'm debating between running a performance snow or a good A/S as a dedicated winter setup.
Coming from truck tires, I can't speak to the Xice3's in the mud, but they are my first snow tire on a car with this much power. I was not expecting the weaker side-wall, but have since gotten used to it. Under hard acceleration and the primacy tires, the car normally wants to sway side to side even though you want it to go in a straight line. This effect is amplified even more by the sidewall strength (weaker or more supple depending on how you want to spin it) in the snow tires it seems. I'm not mad, sad, disappointed, etc. though. It's winter and I was expecting some trade-off in performance.
1. Put some air in the tires.
2. Put a bit more in the rear.
3. Brand new tires still have some mold release on them (and perhaps the mounting lubricant hasn't dried). Drive gently for the first 300-500 miles.
4. One of the things that increases traction in snow tires is that the carcass and tread are flexible so that they wrap around uneven road surfaces allowing more of the contact patch to actually touch the road.
1-2. I am hesitant to inflate above the recommended limits.
I like several others on this forum have gone through back to back VERY tough winters in New England with my Model S with the stock all season tires. To put things in perspective for others in the world, in the last 3 weeks we've had storm(s) of 34+, 24, 20, 18, 16 and 6 inches.....yes that is over 100 inches of snow....in 3 weeks. Cars are buried everywhere and road conditions have been aweful (2 lane streets reduced to 1 lane). The MS with stock tires does not has never spun out, lost control, or got stuck....unlike the SUVs or front wheel drive cars on the road.
So, because of the amazing stability & traction control of the electric drive train of the car, it has handled these horrible horrible conditions without any hiccup. We can even go up slushy hills (where you cannot see the ground) albeit in a manner I've never seen before in a car. I also debated about getting the Michelin ICEs last year but wanted to test out the stock tires first, never needed to. I do switch out the stock all seasons for 20" aftermarket extreme performance summer tires though.
Please also keep in mind that the OP works for a tire reseller.....
The snow we've gotten this year has been atypical in texture--lighter, with very cold roads to start. This is now my third winter with my Model S, and despite the record volumes, it's also been the least taxing for driving. I'd recommend snow tires here in New England as a general matter. Also, "snow tires" are better described as "winter tires" and are made with compounds that retain their flexibility to lower temps. I've really noticed this difference between my wife's BMW 535xi on all-seasons and my Model S; her car feel like we're driving on the rims when it's been below zero.I like several others on this forum have gone through back to back VERY tough winters in New England with my Model S with the stock all season tires. To put things in perspective for others in the world, in the last 3 weeks we've had storm(s) of 34+, 24, 20, 18, 16 and 6 inches.....yes that is over 100 inches of snow....in 3 weeks. Cars are buried everywhere and road conditions have been aweful (2 lane streets reduced to 1 lane). The MS with stock tires does not has never spun out, lost control, or got stuck....unlike the SUVs or front wheel drive cars on the road.
I did a lot of rather obsessive research on this exact topic about three weeks ago. The conclusions were as follows:
The Pirelli's are a "Texas snow tire" - they may do fine with a light dusting, but you can do better.
The two tires that rose to the top out of every discussion were the Xice3 Michelin's and the Hakka 2's. While many claimed one edged out the other and vice versa, not a single source regretted either option.
hat I'm asking boils down to is it the physics of the heavy car or is it the less than optimal winter tires? Based on the first post I know that the Pirellis are a performance winter tire, not a true snow tire. I'm wondering if a true snow tire like the Hakkas can stop my 5000 pound car from sliding so much.
What I'm asking boils down to is it the physics of the heavy car or is it the less than optimal winter tires? Based on the first post I know that the Pirellis are a performance winter tire, not a true snow tire. I'm wondering if a true snow tire like the Hakkas can stop my 5000 pound car from sliding so much.
There would be no doubt that R2 or X-Ice I3 would be better. Also check the pressure in your current tires. No real ice days this year so far, maybe today there will be, but last year on the Primacy tires I had no problem with the back end sliding out (I did have problem with traction on my driveway's steep incline.)
Because it is Physics, what you are interested in is the coefficient of friction of the tire on the surface of interest. Stopping, starting, or lateral acceleration (turns) are determined by the coefficient of friction and is independent of weight.
That being said, my P85D on Hakka R2's is the best winter driving setup I have ever had. I don't have a lot of ice experience, but those limited encounters were uneventful. Lot's snow experience on everything from slush to fresh powder, and those have all been great!
When Tesla offered me a loaner 2WD S on the Pirelli's this winter, I just said no. It's too bad because in the winter of 2012/13, Tesla offered the Nokian Hakka 7's as an option, and they still offer the Nokian Hakka R2's as an option in Norway.
Some other points to consider:
- You'll go through several sets of tires, so you might as well be driving on tires suited to each season.
- Having an extra set of rims at hand gives you the option to carry a full-size spare (albeit, mismatched tires).
