Sub Woofer
Discussion in 'Model S: Interior & Exterior' started by smilepak, Jul 28, 2017.
  1. smilepak
    smilepak Active Member
    Eastvale, CA
    a few questions
    1. Any other brand than NSX and Harmonics making for Model S with molding
    2. What is a decent one for under a grand installed
    3. Where in Southern California?
    I just need some bass not to rock my seat
  2. bakerboy
    bakerboy Member
    So. Cal.
    (I know you said no NVX).......BUT, I had the NVX kit installed in my MS (w/ UHFS) and believe me, its a solid kit for the MS. It completely fills in that lower end spectrum AND totally looks like it came from the factory.
    Just curios as to why you would not consider the NVX kit?
  3. smilepak
    Eastvale, CA
    I would. Wanted to put it out there to see what else are available. If I had left it blank, I'll get a flood of NVX ahaha....
    How much was your kit installed? Not wanting to spend obscene money on it. I might go as high as a grand for a decent one.
  4. bakerboy
    bakerboy Member
    So. Cal.
    I think I paid around $900 for the kit (someone has a discount code) and then a shop in Hacienda Heights did the install for I think about $160, so all in all, just under 1k.
  5. smilepak
    Eastvale, CA
  6. gaslessman79
    gaslessman79 New Member
    Maryland
    Think that is about the lowest ive seen them go for. Unless you want a used unit if you can find one.
