Does anyone know the name/part number of the subwoofer plug/connector on the model 3? I would like to make asplitter for a clean install but cannot find the part number
Splitter for an aftermarket sub I assume? Don't split at the connector, tap the wires further back and then you can have both the OEM sub and your aftermarket sub on at the same time. I used Posi-taps and they worked great.
It plugs into the subwoofer and allows you to run a cable to your Amplifier or Converter, you can leave the subwoofer connected or have it disconnected as you prefer. This part allows you to tap into the Subwoofer signal simply and seamlessly.
