Last night I ran out of battery power for the first time. I was quite surprised. I had an 11km trip and 20 km of range. I have run the car fine on a few occasions and not had a problem so I wasnt too concerned. I thought i would just reduce my speed and i should be fine. It was about 7 degrees C and the car had been sitting for a few hours so i assume the cold battery was a factor. Almost from the start I had markedly reduced power and speed. This should have been a warning to abandon trip but given that the last 1/2 of the trip was steep downhill and thus usually a positive charge I was still confident i would be ok. As I drove the range was falling at a precipitous rate. In the end it dropped from 4 km to 1 km and then 0km over around 500 m and the car announced it was shutting down so I pulled over about 200m short of the downhill stretch on a freeway. I was surprised that all the lights and the screens in the car all shut down pretty much straight away. I thought they would be running off the 12V. Thankfully the hazard lights still worked but the audible click click had stopped. Even the Tesla app connection went off so there was no way to engage tow mode or pop the frunk from the screen or app. Luckily some friends were nearby so picked up the family while I waited for assistance. When the family got out of the car the doors opened and the screens came back on for a short time so I took advantage to pop the front trunk and put the car in tow mode. A word of warning. When you put the car in tow mode it takes the handbrake off so it would be good to carry some wooden blocks in the car to chock the wheels. I was alone by then and the screens went blank again almost as soon as i had put it in tow mode so i was stuck in the car with my foot on the brake as I was on an uphill incline so if I took my foot off the brake the car was going to roll back down the hill so i was stuck waiting for assistance with a foot firmly on the brake hoping it wasnt going to be too long. The next learning point is that Telsa roadside assistance do not cover towing in the event of a flat battery. Thankfully I maintain my RAA cover and they do cover towing up to 10km which was more than enough to get me to my destination. The RAA phone call response was also a lot quicker than Tesla, however I did have to wait a fair while for the tow truck which was a little disconcerting at midnight in 7 degree temps with my foot on the brake. Finally the flat bed tow came and i was glad i had engaged tow mode before the whole system shut down because this made it a lot easier. The tow driver took me the last 5 km home and was able to unload the car and I chocked the wheels with some bricks on the road outside the house. Where I could run an extension cord out to connect to the UMC. Thankfully the charge port opened in response to the charger cable but the cable wouldn’t insert. There is a small plastic tag inside the charge port which locks the charger cable in and this was fixed in the lock position so the charger cable
couldn’t be inserted. I managed to fick it up with a credit card corner and squeeze the charger in. With 10 amp power very little happened for about 30 minutes. Eventually the car came to life and the screens and app connection came back on. I left it for another 30 minutes and it still said 0km but at this point I was confident enough to unplug the UMC and move the car into the garage and onto HPWC.
So the lessons learnt. 1. A cold battery handles very differently to a warm battery. 2. If you get significant power reduction this is the time to find a power outlet, even just a household 10 amp. 3. You have very little time to use the car functions once it does run out of power. Carry chocks. Chock the wheels. Engage tow mode and pop the trunk ASAP. 4. Dont rely on Tesla roadside assistance for a tow. Your local automobile club membership is a better bet. 5. When there is no power it is difficult to plug in the charger. Have some tools on hand to help with this. A thin plastic slightly flexible lever is best. 6 Even once you do connect to power it will take some time to reactivate the vehicle.
