Sudden decrease in Ideal Mileage
cgloewen
11
4
Houston
So a 2010 2.5 Sport, mostly a Sunday Driver. Typically see ideal mileage of around 170 - 175 range. In the past month, the ideal has dropped to 82! The charge bar looks like half charged, so it appears to just need a charge. Range mode bumps it up a bit, not much. CAC shows 142. Any ideas?
im4uttx
354
220
Spicewood, TX
Has the CAC changed in the last month? Ideal just reports what the current charge will get you, so if it needs a charge, can't really base what the ideal number is...unless it won't charge above the current number, which could mean a bad battery sheet...
cgloewen
11
4
Houston
I can't remember the last time I looked at the CAC, so I don't know if it has declined too. Attached is a photo of the ESS SOC, is there a log that shows the CAC values?
im4uttx
354
220
Spicewood, TX
Looks like a bad sheet...the min/max should be within a few %, not 46%-83%, or could just need balanced, but that is a pretty steep difference. Pull the logs and check the history for the worst sheet and it's charge when "full"
The are some better experts and some other threads...
markwj
Moderator, Asia Pacific
Apr 10, 2011
4,584
1,180
Hong Kong
Looks like one or more bad bricks pulling things down. The charge stops when SOC MAX hits the limit, but your displayed SOC / range is limited by SOC MIN.
If you grab the logs, you can have a look at the text file with brick voltages. Should be able to see if it is one or more that are off from the others.
It could also be a bad voltage reading from the BMB, but much more likely to be the brick itself.
Regards, Mark.
Reactions: ICON and Roadster
